Getting percentage from soil Sensor
I am trying to get the percentage humidity from a soil sensor, but I get 0 every time I try to convert the number from the output to a percentage. What am I doing wrong?
This is what I have right now and I get 0:
#include <LiquidCrystal.h>
LiquidCrystal lcd(8,9,4,5,6,7);
lcd.begin(16, 2);
lcd.setCursor(1,0);
lcd.print("Soil Moisture");
lcd.setCursor(3,1);
lcd.print("LEVEL:"); //analog input
lcd.print(int(analogRead(A1)/1024*100));
delay(3000); //change delay to change refresh rate
lcd.setCursor(3,1);
lcd.clear();
If I change this line: lcd.print(int(analogRead(A1)/1024*100)); to this: lcd.print(analogRead(A1)); I get proper numbers between 0 and 1023. I have tried with and without the int() function.
 lcd.print((analogRead(A1)*100L)/1024);
Thank you. But why do I have to do it that way? If I divide by 1024 then multiply by 100 I get the same if I multiply by 100 then divide by 1024.
Edit: I know now. When I divide the number first it is less than one, or rounded to 0, then when I multiply by 100 it is 100*0 so that is what I get.
What does the L after the 100 do?
