Getting response from A9G board
I am using Arduino UNO with A9G board. I am not getting the "OK" response through the code. When i tried through USB to TTL converter, I am getting OK response.
Expected: "OK"
Getting: "No response from GPS module!"
#include <SoftwareSerial.h>
// Define software serial communication pins
const int gpsRxPin = 7;
const int gpsTxPin = 8;
// Create software serial object
SoftwareSerial gpsSerial(gpsRxPin, gpsTxPin);
  // Initialize serial communication for debugging (optional)
  // Begin communication with GPS module at 9600 baud
  gpsSerial.begin(9600);
  // Check for available data from GPS module
  gpsSerial.println("AT");
  if (gpsSerial.available()) {
    String response = gpsSerial.readStringUntil('\n');
    Serial.println("Response: " + response);
    if (response.indexOf("OK") != -1) {
      Serial.println("AT command successful!");
      Serial.println("AT command failed!");
    Serial.println("No response from GPS module!");
based on the tutorial here maybe try something like this:
(Compiles, NOT tested!)
  gpsSerial.println("AT+RST=1"); ////=1 software reset,=2 power off
    while (gpsSerial.available()){
      char c = gpsSerial.read();
      Serial.print(c);
hope that helps...
