Getting some errors in program of rfid tag/card reading
Namaste everyone,
i am Hitendra from INDIA,
i am just verify the id from rfid tag with the help of following project (code), according to the code when i scan the tag/card then it gives the output as i want but the amin problem is,
"When I scan the tag/card second time,then it not scanning. if I scan the card just after second scan then it gives output"
hence the sensor scan the tag/card one time and one time gets paralised so please suggest me some hint,errors,solution in the code so i can solve this query.
Thanking You ( '◡' )
code..,
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11);  // RX, TX
int id[12] = { 0, 'F', 0, 0, 3, 3, 'A', 4, 7, 'E', 'E', 6 };
char reader;
int flag = 0;
  mySerial.begin(9600);
  mySerial.println("Hello, world?");
  if (mySerial.available()) {
    reader = mySerial.read();
    for (int i = 0; i < 12; i++) {
      if (id[i] == reader) {
        flag++;
        if (flag == 12) {
          Serial.print("ha flag 12 hai\n");
          flag = 0;
read() returns an 8-bit value and is you rftag reader returning ASCII chars?
should your ID be
or possibly
the serial processing doesn't look right..
try this..
//int id[12] = { 0, 'F', 0, 0, 3, 3, 'A', 4, 7, 'E', 'E', 6 };
byte id[] = { 0x0F, 0x00, 0x33, 0xA4, 0x7E, 0xE6 };
byte incomingId[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
int charCount = 0;
char reader;
int flag = 0;
    while (mySerial.available()) {
      byte abyte = mySerial.read();
      charCount++;
      if (charCount < sizeof(incomingId)) {
        incomingId[charCount] = abyte;
        if (charCount = sizeof(incomingId) - 1) {
          flag = 1;
  if (flag == 1) {
    //compare arrays..
    if (memcmp(id, incomingId, sizeof(id)) == 0) {
      Serial.println("Tag match");
    //reset flag..
    flag = 0;
    //zero incoming id..
    memset(incomingId, 0, sizeof(incomingId));
Thanks for your valuable appreciation...:v:
But your isn't work
In the my code I get output as I required
But only a problem happens
Is that it recieved the data "one after other"
Can you simplify the errors in the code please!
Is it this that prints "one after the other"?
If so, replace print by println
no brother println just print on new line
by the way i solved this issue by writing another code
thanks for the help😊.
