Hello, this is my first time posting a question so let me know if I posted this in the correct section.
So I have found something interesting in the WPA Connection example for the Giga R1 WiFi
Specifically in this snippet of code from the example:
// attempt to connect to WiFi network:
while (status != WL_CONNECTED)
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
If you comment out the following lines: (the print statements inside the while loop)
Then the mbed os will crash every time you try and run the sketch.
And if you leave the aforementioned lines of code alone, everything works
So my overall questions is why? Why is it that if you remove these print statements the mbed os crashes? Is the WiFi library somehow reliant on serial being used?
Here is the arduino_secrets.h header file
//arduino_secrets.h header file
#define SECRET_SSID ""
#define SECRET_PASS ""
Here is the .ino file
This example connects to an unencrypted WiFi network.
Then it prints the MAC address of the WiFi module,
the IP address obtained, and other network details.
Circuit:
* GIGA R1 WiFi
created 13 July 2010
by dlf (Metodo2 srl)
modified 31 May 2012
by Tom Igoe
modified 22 March 2023
by Karl Söderby
#include <SPI.h>
#include <WiFi.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS; // the WiFi radio's status
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true)
while (status != WL_CONNECTED) {
delay(10000);
// you're connected now, so print out the data:
Serial.print("You're connected to the network");
printCurrentNet();
printWifiData();
// check the network connection once every 10 seconds:
delay(10000);
printCurrentNet();
void printWifiData() {
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
Serial.println(ip);
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC address: ");
printMacAddress(mac);
void printCurrentNet() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print the MAC address of the router you're attached to:
byte bssid[6];
WiFi.BSSID(bssid);
Serial.print("BSSID: ");
printMacAddress(bssid);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.println(rssi);
// print the encryption type:
byte encryption = WiFi.encryptionType();
Serial.print("Encryption Type:");
Serial.println(encryption, HEX);
void printMacAddress(byte mac[]) {
for (int i = 5; i >= 0; i--) {
if (mac[i] < 16) {
Serial.print("0");
Serial.print(mac[i], HEX);
if (i > 0) {
Serial.print(":");
