I received by display shield yesterday, so I thought I would try a few experiments. Like I tried the GigaCameraDisplay example, which worked, which I mentioned over on the Teensy forum:
Teensy 4.1 or Arduino GIGA R1 | Teensy Forum (pjrc.com)
But did not like that the image was rotated 90 degrees and the, and was curious if the display libraries supported rotation of the display at all... So I did a quick and dirty GFX test:
REDIRECT_STDOUT_TO(Serial)
#include "Arduino_GigaDisplay_GFX.h"
GigaDisplay_GFX display;
#define GC9A01A_CYAN 0x07FF
#define GC9A01A_RED 0xf800
#define GC9A01A_BLUE 0x001F
#define GC9A01A_GREEN 0x07E0
#define GC9A01A_MAGENTA 0xF81F
#define GC9A01A_WHITE 0xffff
#define GC9A01A_BLACK 0x0000
#define GC9A01A_YELLOW 0xFFE0
uint16_t colors[] = {GC9A01A_RED, GC9A01A_BLUE, GC9A01A_GREEN, GC9A01A_RED, GC9A01A_BLUE, GC9A01A_BLACK};
while (!Serial && millis() < 5000) { }
uint8_t rotation = 3;
rotation = (rotation + 1 ) & 0x3;
display.setRotation(rotation);
printf("Rotation: %u, W:%u H:%u\n", rotation, display.width(), display.height());
display.fillScreen(colors[rotation]);
display.fillRect(120, 180, 120, 180, 0x8888);
display.setTextSize(4);
display.setCursor(display.width()/2, display.height() / 2);
display.print(rotation);
Which worked.
So, I then made a modified version of the camera display software that uses GFX:
Ran into a few issues with the code, like:
g_camera_width = cam.getResolutionWidth();
g_camera_height = cam.getResolutionHeight();
Found that these two functions are in the header file, but are not implemented.
Thought about checking/issuing ISSUE or the like, but already something like 186 open issues and 26 open Pull Requests, so not sure if this library is being maintained or not...
Also ran into issue with the sketch include:
#include "SDRAM.h"
As one of the library header files I included also include it, and this header file is not protected:
i.e. it does not either have:
#pragma once
Or a check like:
#ifndef __SDRAM_H__
#define __SDRAM_H__
#endif
EDIT: - forgot to mention that, the camera did not work if I did:
fb.setBuffer((uint8_t *)SDRAM.malloc(640 * 480 * 2));
As the memory was not aligned to 32 byte boundary like it does internal to the library when it calls malloc... So I put in the alignment code:
(End Edit)
But got it to compile and run:
#define ALIGN_PTR(p,a) ((p & (a-1)) ?(((uintptr_t)p + a) & ~(uintptr_t)(a-1)) : p)
#include "arducam_dvp.h"
//#include "SDRAM.h"
// This example only works with Greyscale cameras (due to the palette + resize&rotate algo)
//#define ARDUCAM_CAMERA_HM01B0
#include "OV7670/ov767x.h"
OV7670 ov767x;
//OV7675 ov767x;
Camera cam(ov767x);
#define IMAGE_MODE CAMERA_RGB565
// The buffer used to capture the frame
FrameBuffer fb;
// The buffer used to rotate and resize the frame
uint16_t g_camera_width;
uint16_t g_camera_height;
void blinkLED(uint32_t count = 0xFFFFFFFF) {
pinMode(LED_BUILTIN, OUTPUT);
while (count--) {
digitalWrite(LED_BUILTIN, LOW); // turn the LED on (HIGH is the voltage level)
delay(50); // wait for a second
digitalWrite(LED_BUILTIN, HIGH); // turn the LED off by making the voltage LOW
while (!Serial && millis() < 5000) {}
// Init the cam QVGA, 30FPS
SDRAM.begin();
Serial.println("Before camera start"); Serial.flush();
if (!cam.begin(CAMERA_R640x480 /*CAMERA_R320x240 */, IMAGE_MODE, 10)) {
blinkLED();
Serial.println("Before setBuffer"); Serial.flush();
uint8_t *fb_mem = (uint8_t *)SDRAM.malloc(640 * 480 * 2 + 32);
fb.setBuffer((uint8_t *)ALIGN_PTR((uintptr_t)fb_mem, 32));
printf("Frame buffer: %p\n", fb.getBuffer());
// clear the display (gives a nice black background)
Serial.println("Before setRotation"); Serial.flush();
display.begin();
display.setRotation(3);
Serial.println("Before fillscreen"); Serial.flush();
display.fillScreen(GC9A01A_BLUE);
g_camera_width = 640; //320; //cam.getResolutionWidth();
g_camera_height = 480; //240; //cam.getResolutionHeight();
Serial.println("end setup"); Serial.flush();
#define HTONS(x) (((x >> 8) & 0x00FF) | ((x << 8) & 0xFF00))
// Grab frame and write to another framebuffer
if (cam.grabFrame(fb, 3000) == 0) {
// We need to swap bytes.
uint16_t *pixels = (uint16_t *)fb.getBuffer();
for (int i = 0; i < g_camera_width * g_camera_height; i++) pixels[i] = HTONS(pixels[i]);
display.drawRGBBitmap((display.width() - g_camera_width) / 2, (display.height() - g_camera_height) / 2, pixels, g_camera_width, g_camera_height);
blinkLED(20);
Note: I did not like the camera orientation in different orientation from the display, so used an adapter I made a while ago for my Teensy 4.1 board which rotates it...
Now back to playing.... Maybe convert one of my SD Image viewers I have for some TFT displays...
