Global var in a common globals.h file and redefinition errors
Hello,
my project uses several cpp files so I put global variables in a common globals.h file.
In each cpp file I use some guard like
> #ifndef Globals_h
> #include "globals.h"
> #endif
and in globals.h file
#ifndef Globals_h
#define Globals_h
#include "BarGraphControler.h"
#include "CommunicationWithESP.h"
BarGraphControler barGraphControler;
CommunicationWithESP communicationWithESP;
#endif
Despite those guards I can't compile successfully, I get redefinition var errors like
globals.cpp:5:19: error: redefinition of 'BarGraphControler barGraphControler'
any explanation ?
Thanks
Bernard
Your guard just prevents from importing twice in the same file. but not across files, so you end up with multiple definitions
you want global variables defined (memory allocated) in a .cpp. This way you are sure it's only done once. In the .h you just declare them extern. The linker will find them where they are.
You probably do not understand the meaning of your guards. Each .cpp file is compiled separately, your construction works only inside one file.
Thus, your globals.h file will be included in the compilation as many times as you have .cpp files in your project - if there are more than one, you will get a variable redefinition error.
I misunderstood how works the #ifndef, I usually use java not cpp.
Ok so I remove the #include "globals.h" in my CommunicationWithESP.h and put
extern BarGraphControler barGraphControler;
Then I leave in globals.h
And it works, thanks a lot.
The "extern" declarations should reside in the common header file. A separate .cpp file or the program main file then contains all non-extern declarations.
here is an example of organisation
globals.h
// define stuff that needs to be shared
extern int var1;
extern long var2;
extern void func1(int);
extern void func2(long);
file1.cpp
int var1 = 22;
void func1(int x) { var1 = x;}
file2.cpp
long var2 = 33;
void func2(long x) { var2 = x;}
demo.ino
  Serial.println("before");
  Serial.print("var1 = "); Serial.println(var1);
  Serial.print("var2 = "); Serial.println(var2);
  func1(100);
  func2(200);
  Serial.println("after");
void loop() {}
