GMAIL SMTP Gone?
EPS32-CAM
Program is a trail cam. It was working for the past 2 years. Gmail sent me a notice that SMTP has been suspended. Is there any Free SMTP that will work?
I tried my ISP but they do not support SMTP ether.
What exactly did the message from Gmail say?
It may be that this applies only to your account and is temporary.
If your account has been compromised and someone was using it to send spam, then it could have been suspended. Try changing the password and try again sometime later.
See also SMTP relay spam policy in Gmail - Google Workspace Admin Help
Gmail also require you to now tick boxes that indicate you are ok for unknown applications to generate SMTP request via the Gmail account. Might just need to check those settings.
Are you using smtp.gmail.com port 465 (SSL) or port 587 (TLS)?
I was using an esp to send gmail too, it's dead now. google turned it off.
to johnwasser, I found this on YouTube but it did not work either
* This demo sketch will fail at the Gmail login unless your Google account has
* set the following option:
*     Allow less secure apps: OFF
* which can be found in your Google account under Security. You will get an email
* warning from Google that the universe will implode if you allow this.
* see https://www.base64encode.org/ for encoding / decoding
#include <base64.h>
#include <ESP8266WiFi.h>
#include "Config.h"
* const char* _ssid = "Greypuss";
* const char* _password = "mypassword";
* const char* _GMailServer = "smtp.gmail.com";
* const char* _mailUser = "mygmailaddress@gmail.com";
* const char* _mailPassword = "my Google password";
const char* ssid = _ssid;
const char* fingerprint = "289509731da223e5218031c38108dc5d014e829b"; // For smtp.gmail.com
WiFiClientSecure client;
// Forward declarations of functions (only required in Eclipse IDE)
byte response();
byte sendEmail();
 Serial.begin(74880);
 delay(10);
 // Connect to WiFi network
 Serial.print("Connecting to ");
 Serial.println(ssid);
 WiFi.begin(_ssid, _password);
   Serial.print(".");
 Serial.println("");
 Serial.println("My IP address: ");
 sendEmail();
//Nothing to do here. Never send email in a loop. You will get blacklisted.
// Function send a secure email via Gmail
byte sendEmail()
 //client.setFingerprint(fingerprint); // not available in axTLS::WiFiClientSecure 4.2.2
 // port 465=SSL 567=TLS; 587 not available with library 4.2.2
 // this all needs Google security downgrading:
 // https://myaccount.google.com/lesssecureapps?utm_source=google-account&utm_medium=web
* Gmail exposes port 465 for SMTP over SSL and port 587 for SMTP with STARTTLS.
* The difference between these two is that SMTP over SSL first establishes a secure
* SSL/TLS connection and conducts SMTP over that connection, and SMTP with STARTTLS
* starts with unencrypted SMTP and then switches to SSL/TLS.
* See https://stackoverflow.com/questions/17281669/using-smtp-gmail-and-starttls
 Serial.println("Attempting to connect to GMAIL server");
 if (client.connect(_GMailServer, 465) == 1) {
   Serial.println(F("Connected"));
   Serial.print(F("Connection failed:"));
   return 0;
 if (!response())
   return 0;
 Serial.println(F("Sending Extended Hello"));
 client.println("EHLO gmail.com");
 if (!response())
   return 0;
 // We're not using port 567 in this demo
 //Serial.println(F("STARTTLS"));
 //if (!response())
 //  return 0;
 //Serial.println(F("Sending EHLO"));
 //client.println("EHLO gmail.com");
 //if (!response())
 //  return 0;
 Serial.println(F("Sending auth login"));
 client.println("auth login");
 if (!response())
   return 0;
 Serial.println(F("Sending User"));
 // Change to your base64, ASCII encoded user
 client.println(base64::encode(_mailUser));
 if (!response())
   return 0;
 Serial.println(F("Sending Password"));
 // change to your base64, ASCII encoded password
 client.println(base64::encode(_mailPassword));
 if (!response())
   return 0;
 Serial.println(F("Sending From"));
 // your email address (sender) - MUST include angle brackets
 client.println(F("MAIL FROM: <arduinitepower@gmail.com>"));
 if (!response())
   return 0;
 // change to recipient address - MUST include angle brackets
 Serial.println(F("Sending To"));
 client.println(F("RCPT To: <ralph@gmail.com>"));
 // Repeat above line for EACH recipient
 if (!response())
   return 0;
 Serial.println(F("Sending DATA"));
 client.println(F("DATA"));
 if (!response())
   return 0;
 Serial.println(F("Sending email"));
 // recipient address (include option display name if you want)
 client.println(F("To: Home Alone Group<totally@made.up>"));
 // change to your address
 client.println(F("From: HomeAlone@gmail.com"));
 client.println(F("Subject: Your Arduino\r\n"));
 client.println(F("This email was sent securely via an encrypted mail link.\n"));
 client.println(F("In the last hour there was: 8 activities detected. Please check all is well."));
 client.println(F("This email will NOT be repeated for this hour.\n"));
 client.println(F("This email was sent from an unmonitored email account - please do not reply."));
 client.println(F("Love and kisses from Dougle and Benny. They wrote this sketch."));
 // IMPORTANT you must send a complete line containing just a "." to end the conversation
 // So the PREVIOUS line to this one must be a prinln not just a print
 client.println(F("."));
 if (!response())
   return 0;
 Serial.println(F("Sending QUIT"));
 client.println(F("QUIT"));
 if (!response())
   return 0;
 client.stop();
 Serial.println(F("Disconnected"));
 return 1;
// Check response from SMTP server
byte response()
 // Wait for a response for up to X seconds
 int loopCount = 0;
 while (!client.available()) {
   delay(1);
   loopCount++;
   // if nothing received for 10 seconds, timeout
   if (loopCount > 10000) {
     client.stop();
     Serial.println(F("\r\nTimeout"));
     return 0;
 // Take a snapshot of the response code
 byte respCode = client.peek();
 while (client.available())
   Serial.write(client.read());
 if (respCode >= '4')
   Serial.print("Failed in eRcv with response: ");
   Serial.print(respCode);
   return 0;
 return 1;
}type or paste code here
