Goertzel TONE(440.0);
Hi
The code is taken from here
https://github.com/AI5GW/Goertzel/tree/main
and it has compiling errors
 *  SingleTone.ino - Goertzel library example
 * Copyright (C) 2022 Sebastian Westerhold (AI5GW) <sebastian@baltic-lab.com>
 * Web (EN): https://baltic-lab.com
 * Web (DE): https://baltic-labor.de/
 * YouTube (EN): https://www.youtube.com/c/BalticLab
 * This program is free software: you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation, either version 3 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program.  If not, see <http://www.gnu.org/licenses/>.
// Define the ADC midpoint (512 is the default)
#define ADC_MIDPOINT 512
// Define the sample rate (8800 S/s is the default for 16 MHz Boards)
#define SAMPLE_RATE 8800
// include the Goertzel library
#include <Goertzel.h>
// Array buffer for ADC samples
int Samples[100];
// Variable for resulting magnitude
float Mag;
// Instantiate class for 440 Hz tone detection
  // Get 100 ADC samples from A1 and store them in the buffer
  for (int n = 0; n < 100; n++) {
    Samples[n] = analogRead(A1);
  // get the magnitude of the 440 Hz tone
  // The second parameter is the amount of samples passed to the class function
  Mag = TONE.Mag(Samples, 100);
  // print result to serial
  Serial.println(Mag);
errors Arduino uno
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
Warning: Board New folder:arduino:uno doesn't define a 'build.board' preference. Auto-set to: ARDUINO_UNO
Warning: Board New folder:arduino:fio doesn't define a 'build.board' preference. Auto-set to: ARDUINO_FIO
Warning: Board New folder:arduino:atmega168 doesn't define a 'build.board' preference. Auto-set to: ARDUINO_ATMEGA168
Warning: Board New folder:arduino:nano doesn't define a 'build.board' preference. Auto-set to: ARDUINO_NANO
Warning: Board New folder:arduino:lilypad328 doesn't define a 'build.board' preference. Auto-set to: ARDUINO_LILYPAD328
Warning: Board New folder:arduino:mega doesn't define a 'build.board' preference. Auto-set to: ARDUINO_MEGA
Warning: Board New folder:arduino:bt doesn't define a 'build.board' preference. Auto-set to: ARDUINO_BT
Warning: Board New folder:arduino:pro328 doesn't define a 'build.board' preference. Auto-set to: ARDUINO_PRO328
Warning: Board New folder:arduino:pro doesn't define a 'build.board' preference. Auto-set to: ARDUINO_PRO
Warning: Board New folder:arduino:lilypad doesn't define a 'build.board' preference. Auto-set to: ARDUINO_LILYPAD
Warning: Board New folder:arduino:diecimila doesn't define a 'build.board' preference. Auto-set to: ARDUINO_DIECIMILA
Warning: Board New folder:arduino:pro5v doesn't define a 'build.board' preference. Auto-set to: ARDUINO_PRO5V
Warning: Board New folder:arduino:atmega328 doesn't define a 'build.board' preference. Auto-set to: ARDUINO_ATMEGA328
Warning: Board New folder:arduino:mini328 doesn't define a 'build.board' preference. Auto-set to: ARDUINO_MINI328
Warning: Board New folder:attiny:attiny44-8 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY44-8
Warning: Board New folder:attiny:attiny44-20 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY44-20
Warning: Board New folder:attiny:attiny45-8 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY45-8
Warning: Board New folder:attiny:attiny85-20 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY85-20
Warning: Board New folder:attiny:attiny45-20 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY45-20
Warning: Board New folder:attiny:attiny84-8 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY84-8
Warning: Board New folder:attiny:attiny84-20 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY84-20
Warning: Board New folder:attiny:attiny85 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY85
Warning: Board New folder:attiny:attiny85-8 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY85-8
Warning: Board New folder:attiny:attiny44 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY44
Warning: Board New folder:attiny:attiny84 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY84
Warning: Board New folder:attiny:attiny45 doesn't define a 'build.board' preference. Auto-set to: ATTINY_ATTINY45
goertzel_4:39:20: error: no matching function for call to 'Goertzel::Goertzel(double)'
In file included from C:\Users\Galinka\Documents\Arduino\goertzel_4\goertzel_4.ino:30:0:
C:\Users\Galinka\Documents\Arduino\libraries\Goertzel-master/Goertzel.h:35:5: note: candidate: Goertzel::Goertzel(float, float)
     Goertzel(float,float);
C:\Users\Galinka\Documents\Arduino\libraries\Goertzel-master/Goertzel.h:35:5: note:   candidate expects 2 arguments, 1 provided
C:\Users\Galinka\Documents\Arduino\libraries\Goertzel-master/Goertzel.h:34:5: note: candidate: Goertzel::Goertzel(float, float, float)
     Goertzel(float,float,float);
C:\Users\Galinka\Documents\Arduino\libraries\Goertzel-master/Goertzel.h:34:5: note:   candidate expects 3 arguments, 1 provided
C:\Users\Galinka\Documents\Arduino\libraries\Goertzel-master/Goertzel.h:30:7: note: candidate: constexpr Goertzel::Goertzel(const Goertzel&)
 class Goertzel
C:\Users\Galinka\Documents\Arduino\libraries\Goertzel-master/Goertzel.h:30:7: note:   no known conversion for argument 1 from 'double' to 'const Goertzel&'
C:\Users\Galinka\Documents\Arduino\libraries\Goertzel-master/Goertzel.h:30:7: note: candidate: constexpr Goertzel::Goertzel(Goertzel&&)
C:\Users\Galinka\Documents\Arduino\libraries\Goertzel-master/Goertzel.h:30:7: note:   no known conversion for argument 1 from 'double' to 'Goertzel&&'
C:\Users\Galinka\Documents\Arduino\goertzel_4\goertzel_4.ino: In function 'void loop()':
goertzel_4:54:14: error: 'class Goertzel' has no member named 'Mag'
exit status 1
sounds like an issue with the IDE and the boards' definitions.
I fixed it by uploading library from linkedin page. Testing results are not good
  1. no goertzel effect = magnitude almost not depends to signal frequency.
  2. changing ADC MIDPOINT 512 to another number is not affecting
could indicate that you are using an example from this library https://github.com/AI5GW/Goertzel/tree/main
using the Goertzel.h from this library
https://github.com/jacobrosenthal/Goertzel/tree/master
after installing this one I have no errors,
I had errors when only the second library was installed
