Going to the start of loop after an Interrupt
Hello,
I went jump to the loop() so the program starts from de beginning after an software interrupt.
( Arduino DUE )
The program I have added does not works.
Please a tip what I need to change so that it works.
Thanks in advance,
Leen
#include <DueTimer.h>
volatile byte state = LOW;
int LED_1 = 41;
int LED_2 = 53;
pinMode(LED_1,OUTPUT);
pinMode(LED_2,OUTPUT);
Timer3.attachInterrupt(MSec).start(1000); // Every ms
void(* resetFunc) (void) = 0; // Declare reset function @ address 0
digitalWrite(LED_2, HIGH); // Short pulse
while (1){
digitalWrite(LED_2, LOW); // Reset pulse
void MSec(){
state = !state;
digitalWrite(LED_1, state);
resetFunc(); // Return to loop
An interrupt returns to the position the program was at when it was called . If you return elsewhere you are likely to have problems caused by incompleted routines . Not good practice and can’t see why you would want to do that.
You could set a flag in the interrupt service routine and check for that on exit , and not preform any further actions in loop ( by checking if the flag is set) until you again reach the top of loop , where you reset the flag.
No idea what’s wrong with the rest of it... looks a bit odd tho
This does not "return to loop", it reboots the Arduino.
If you leave out the while {}, the loop function will exit and immediately be reentered.
Please use code tags when posting code ("</>" editor button).
Hello,
This program is only to test the jump back from the interrupt to first step of program code.
Thanks for the information.
Leen
