Hello,
I am really struggling with my code, I have tried to archive what I want for a long time.
I have a SONOFF Basic, so it’s basically a ESP8266, and reprogrammed it with the Arduino IDE.
GPIO14 is used as an Input. If it's LOW the relay should close and vise versa. GPIO14 has a PULLUP Resistor.
Now I want to use the GPIO0, which is a Button to toggle the relay as well.The button is already soldered on the PCB of the SONOFF.
In short what I want to archive is a GPIO Input and Button Input as a toggle button of the same Output:
- GPIO14 is either HIGH or LOW. HIGH = Relay closed, LOW = Relay open
- GPIO0 is a connected to a button. LOW when pressed. HIGH when released.
It should work like a toggle button:
-> relay is open -> press button -> relay is closed -> press button -> relay is open -> … - and if GPIO14 is LOW the relay should be open as well, to avoid a closed relay when the Input on
GPIO14 is LOW if it gets LOW due to a crash or not powered MCU where the Input for the GPIO14 is
coming from.
I have written a code which archives nearly this. The Input from GPIO14 is controlling the relay as it should, but the GPIO0 only works half as I like it. It only closes the relay when the button is pressed, when it is released the relay opens again.
My Code looks like this:
const int detect = 14;
const int relay = 12;
const int led = 13;
const int button = 0;
bool current_ledState = 0;
bool detect_state;
bool button_state = 0;
pinMode(detect, INPUT);
pinMode(relay, OUTPUT);
digitalWrite(relay, LOW); //LOW = OFF
pinMode(led, OUTPUT);
digitalWrite(led, HIGH); //HIGH = LED is OFF
pinMode(button, INPUT);
detect_state = digitalRead(detect); //NodeMCU gibt vor ob Licht ON oder OFF sein soll
button_state = digitalRead(button)
Serial.print("current_ledState: "); Serial.println(current_ledState);
Serial.print("detect_state: "); Serial.println(detect_state);
Serial.print("button_state: "); Serial.println(button_state);
if (button_state == 0) {
digitalWrite(relay, HIGH);
digitalWrite(led, LOW);
current_ledState = 1;
Serial.println("Relay ON 2");
else if (detect_state == 1 && current_ledState == 0) {
Serial.println("Relay ON 1");
else if (detect_state == 0 && current_ledState == 1) {
Serial.println("Relay OFF 1");
else {
Serial.println("STAY AS IT IS");
Serial.println("-------------------------");
I hope I haven’t written it too confusing. Thanks
