GPRS Shield code
Hi, Ive started arduino about a year ago and I was wondering how i could use a gprs shield. I placed my GPRS shield on the arduino UNO and it lit up. Yet, the code was had issues and I used a tinySine gprs shield.
The code is as follows:
#include <GSM.h>
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess; // include a 'true' parameter for debug enabled
GSM_SMS sms;
char remoteNumber[20]= "14086851138";
// char array of the message
char txtMsg[200]="RUN IT OFFFFFFFFF YUH";
// initialize serial communications
Serial.println("SMS Messages Sender");
// connection state
boolean notConnected = true;
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while(notConnected)
if(gsmAccess.begin()==GSM_READY){
notConnected = false;
Serial.println("Not connected");
Serial.println("GSM initialized");
sendSMS();
// nothing to see here
void sendSMS(){
Serial.print("Message to mobile number: ");
Serial.println(remoteNumber);
// sms text
Serial.println("SENDING");
Serial.println("Message:");
Serial.println(txtMsg);
// send the message
sms.beginSMS(remoteNumber);
sms.print(txtMsg);
sms.endSMS();
Serial.println("\nCOMPLETE!\n");
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. If your browser doesn't show the posting toolbar then you can just manually add the code tags:
[code]``[color=blue]// your code is here[/color]``[/code]
Using code tags and other important information is explained in the How to use this forum post. Please read it.
arduino_user:
Don't you think it would be helpful to explain what those issues were?
Please reply asa
Thank you for any help
The gprs shield is from: https://www.ebay.com/itm/221236220201?rmvSB=true
The code has no errors, but when I run it, it doesn't work after writing SMS Messager and it stops
Please help asap thank you so much...
