GPS and GSM interface for remote TCp server
Hello,
I m working on GPS Locator n i want help in interface GPS and GSM that is use to send latitude and longitude value to the TCP server over internet.I have configured my laptop as a TCp server and GSM module as client
I have the below sketch for GPS , which is working as expected:
#include <Adafruit_GPS.h>
#include <String.h>
#include <SoftwareSerial.h>
SoftwareSerial myserial(3,2); //This is a serial port where TX[3 port] and RX[2 port] are connected
Adafruit_GPS GPS(&myserial);   //Create the GPS object
String NMEA1;  // Hold the GPS data
String NMEA2;  // Hold the GPS data
char c;
  Serial.begin(115200); //Turn on serial Monitor
  GPS.begin(9600); // Turn on GPS at 9600 Baud rate Speed
  GPS.sendCommand("$PGCMD,33,0*6D"); //Turns off the antenna for garbage value
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); //To keep the data sort successfullt
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);  // Only RMC and GGA will taken into consideration
  delay(3000);
  readGPS();
void readGPS(){
  while(!GPS.newNMEAreceived()){
    c=GPS.read();
  GPS.parse(GPS.lastNMEA());
  NMEA1=GPS.lastNMEA();
    c=GPS.read();
  NMEA2=GPS.lastNMEA();
  Serial.println(NMEA1);
  Serial.println(NMEA2);
  Serial.println("");
Below is the GSM sketch which I am able to connect via USb connector for Remote TCP server:
AT
AT+CIPSHUT
AT+CIPMUX=0
AT+CGATT=1
AT+CSTT="APN",<Userid>,<Password>
AT+CIICR
AT+CISF
AT+CIPSTART="TCP",<PIBLICIP>,<PORT>
AT+CIPSEND
I want to integrate both GPS and GSM module which will connect and send GPS data over internet to the TCP server.
Please help me to resolve the issue.
Thanks-
Pokhraj
That doesn't look anything like a sketch.
You haven't told us what the issue is.
Thanks you for the response.
I want to integrate GSM with GPS module, which will send the location [long,lat] to my TCP port[which I mentioned at GSM portion], through internet.
My plan is I will carry the GPS and GSM module with powerbank and it will send the current location status at server's TCP port.
Thanks-
Pokhraj Das
So, what IS the problem?
I cannot integrate both the codes for ardunio. Not sure what are all the libraries I need to refer.
I am using GSM SIM900A module. Do I need to include SIM900A.h at arduino sketch.
Please suggest.
Thanks-
Pokhraj das
Both of the one code you posted?
For what purpose?
Most likely.
It does not appear that you have any requirements. Start by making a DETAILED list of what the program is actually supposed to do, with as much detail as possible.
Hello,
Sorry for the delay.
Please find the below code ... But no GPS data is coming.. Is there is any mistake..
#include "TinyGPS.h"
SoftwareSerial gpsSerial(4, 3);  //4 is for TX and 3 is for RX
TinyGPS gps; // create gps object
  gpsSerial.begin(9600); // connect gps sensor
  delay(2000);
  static int count = 0;
  static long lat=0,lon=0;
    while(gpsSerial.available()) { // check for gps data
      if(gps.encode(gpsSerial.read())) { // encode gps data
        gps.get_position(&lat,&lon,null); // get latitude and longitude
        Serial.println(lat);
        Serial.println(", ");
        Serial.println(lon);
Thanks-
Pokhraj
With that code, you do NOT know that.
Store the value read from the GPS and print it. That way, you'll KNOW whether there is data coming in from the GPS. If not, then perhaps you have the TX and RX lines swapped. If there is, but it doesn't look right, perhaps you have a baud rate issue.
Debugging by guesswork is the worst possible way to debug code.
Could you please help me to store the GPS data into string? My sketch is working
Thanks-
Pokhraj
Why? The decode() method already does that.
gps.encode()
Each byte of NEMA data must be giving to TinyGPS by using encode(). True is returned when new data has been fully decoded and can be used
Is there is again required decode function to decode the NMEA data?
Thanks-
Pokhraj
I'm not sure that I understand your question. The decode() function has to be given each character read from the GPS. It stores the characters in an array, and determines if any given character is the one that says "this is the end of a GPS sentence". When it gets one that is, it parses the stored data, and returns true, indicating that you can now use the parsed data. If the character is not the one that says that a sentence is complete, decode() returns false, meaning that you should not be using the parsed data.
I understood your explanation.
Could you please advice how to use the decode().
Thanks-
Just like this:
Except that I'd store the character and print it, too. And, I'd position the curly braces better. And, I'd ditch the comments that add no value.
       char c = gpsSerial.read();
       Serial.print(c);
       if(gps.encode(c))
Thank you Sir.... Code is working.... One small question?
Serial.print(c);
If I comment out the line and re-construct in different way like below.. No data I am able to found at my serial monitor..
      // Serial.print(c);
      if(gps.encode(c)) { // encode gps data
        gps.get_position(&lat,&lon);
        Serial.print("Position: ");
        Serial.print("lat: ");Serial.print(&lat);Serial.print(" "); Serial.print("lon: ");Serial.print(&lon);
Thanks-
Pokhraj
With that line in place, you get some serial data that you haven't shared. Without it, you don't get any. One can only conclude, then, that decode() is never returning true. Do you understand what that means? Do you think that it might be important to share what only you can see, like the serial output?
Awesome.... Thanks for the update.
Here is the new set of code: The only task I want to perform is to send the SMS to my number 9007558976:
#define RXPIN 3
#define TXPIN 4
SoftwareSerial gpsSerial(TXPIN , RXPIN);  //4 is for TX and 3 is for RX
const int timesTosend=1;
char phone_no[]="9007558976";
  delay(2000);
  Serial.println("AT+CMGF=1");
  delay(200);
  if (count < timesTosend)
      Serial.print(c);
        gps.get_position(&lat,&lon); // get latitude and longitude
        Serial.print("AT+CMGS=\"");
        Serial.print(phone_no);
        Serial.println("\"");
        // Wait for '>'
        while(Serial.read() != '>');
        Serial.print(lat);
        Serial.print(", ");
        Serial.print(lon);
        Serial.write(0x0D);  // Carriage Return in Hex
        Serial.write(0x0A);  // Line feed in Hex
        Serial.write(0x1A);  // sends ctrl+z end of message
        count++;
        //The 0D0A pair of characters is the signal for the end of a line and beginning of another.
        delay(5000);
While compiling I am facing the below error :
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x24
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x52
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x4d
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x2c
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x2c
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x56
An error occurred while uploading the sketch
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x2c
Please advice ..
Thanks-
Pokhraj
Hello,
the error has gone.... What I did , I remove the RX of GSM from arduino [RX 0] to another pin 5.
The compilation error gone. But the SMS is not coming at my mobile.
Any error at my code?
Please advice
Thanks-
Pokhraj
        // Wait for '>'
Once again you are failing to take the opportunity to print the message coming from the device, so you are missing what the device might be telling you, in terms of what is wrong.
You REALLY need a Mega for this project, so you can have 2 external serial devices connected and still be able to use Serial for debugging.
