Hi everyone,
I’ve been working on a project that uses a u-blox GPS NEO6MV2 with a NiceRF 2AD66 LoRa device which uses a SX1276 chip. Using the GPS and the LoRa separately they work just fine with the example programs of their libraries (LoRa from sandeepmistry, TinyGPS and TInyGPS++ from mikalhart), even though the GPS had trouble finding a fix sometimes. However, when I used both at the same time, to transmit the gps coordinates, it simply did not work. I tried using a Teensy 4.0 and an Arduino Nano as microcontrollers. Does anyone have ideas for a solution?
Code using both at the same time:
#include <SPI.h>
#include <LoRa.h>
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
This sample sketch demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
boolean once = true;
float LAT = 0, LNG = 0;
long wtime = 0;
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
int counter = 0;
ss.begin(GPSBaud);
Serial.println(F("DeviceExample.ino"));
Serial.println(F("A simple demonstration of TinyGPS++ with an attached GPS module"));
Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
Serial.println(F("by Mikal Hart"));
Serial.println("LoRa Sender");
if (!LoRa.begin(915E6)) {
Serial.println("Starting LoRa failed!");
while (1);
/*------------------------------Coleta de dados do GPS------------------------*/
while (ss.available() > 0)
if (gps.encode(ss.read()))
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
while(true);
/*------------------------------Verificação de dados do GPS------------------------*/
//Quantidade de satélites:
Serial.print(gps.satellites.value());
//LATITUDE+LONGITUDE
if (gps.location.isValid())
LAT = (gps.location.lat(), 6);
Serial.print(F(","));
LNG = (gps.location.lng(), 6);
if(once == true){
wtime = millis();
once = false;
Serial.print(wtime);
Serial.println(F("INVALID LOCATION"));
//DATA
Serial.print(F(" Date/Time: "));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F("/"));
Serial.print(gps.date.day());
Serial.print(gps.date.year());
Serial.print(F("INVALID DATA"));
//TIME
Serial.print(F(" "));
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F("0"));
Serial.print(gps.time.hour());
Serial.print(F(":"));
if (gps.time.minute() < 10) Serial.print(F("0"));
Serial.print(gps.time.minute());
if (gps.time.second() < 10) Serial.print(F("0"));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F("0"));
Serial.print(gps.time.centisecond());
Serial.print(F("INVALID TIME"));
LoRa.beginPacket();
LoRa.print("Packet number: ");
LoRa.print(counter);
LoRa.print(gps.satellites.value());
LoRa.print(LAT);
LoRa.print(LNG);
LoRa.endPacket();
counter++;
