GPS coordinates ( altitude , longitude ) shows all 0
Hi Guys ,
MKR 1500 with GPS shield attached. Sketch Example Arduino_MKRGPS GPSlocation.ino
GPS coordinates ( altitude , longitude ) shows all 0 . any help will be appreciated .
  Sketch generated by the Arduino IoT Cloud Thing "Untitled"
  https://create.arduino.cc/cloud/things/84b0b52f-20a4-4f0e-bf93-2bb09584fa83
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  CloudLocation coordinates;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include <Arduino_MKRGPS.h>
#include "thingProperties.h"
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // If you are using the MKR GPS as shield, change the next line to pass
  // the GPS_MODE_SHIELD parameter to the GPS.begin(...)
  if (!GPS.begin()) {
    Serial.println("Failed to initialize GPS!");
    while (1);
    else Serial.println("GPS Ready");
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
     The following function allows you to obtain more information
     related to the state of network and IoT Cloud connection and errors
     the higher number the more granular information you’ll get.
     The default is 0 (only errors).
     Maximum is 4
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  ArduinoCloud.update();
  // Your code here
    float lat   = GPS.latitude();
    float lon  =  GPS.longitude();
    //coordinates = Location(GPS.latitude(),GPS.longitude());
    coordinates = Location(lat, lon);
    // print GPS values
    Serial.print("Location: ");
    Serial.print(lat, 7);
    Serial.print(", ");
    Serial.println(lon, 7);
For informed help, please read and follow the instructions in the "How to get the best out of this forum" post, linked at the head of every forum category.
Explain your setup, post links to devices, post all the code, using code tags, (for text as well), and avoid posting illegible screenshots.
By the way, you need to be outside, with a clear view of the sky, for a GPS to work.
What does GPS.available() return?
Thanks for your Replay:
I modified the sketch here is the original code .
  GPS Location
  This sketch uses the GPS to determine the location of the board
  and prints it to the Serial monitor.
  Circuit:
   - MKR board
   - MKR GPS attached via I2C cable
  This example code is in the public domain.
  while (!Serial) {
  if (!GPS.begin()) {
    while (1);
  // check if there is new GPS data available
  if (GPS.available()) {
    // read GPS values
    float latitude   = GPS.latitude();
    float longitude  = GPS.longitude();
    float altitude   = GPS.altitude();
    float speed      = GPS.speed();
    int   satellites = GPS.satellites();
    // print GPS values
    Serial.print(latitude, 7);
    Serial.print(", ");
    Serial.println(longitude, 7);
    Serial.print("Altitude: ");
    Serial.print(altitude);
    Serial.println("m");
    Serial.print("Ground speed: ");
    Serial.print(speed);
    Serial.println(" km/h");
    Serial.print("Number of satellites: ");
    Serial.println(satellites);
this code works fine without uploading it to the cloud. I get error if uploaded to cloud and add Variable . that why I modify it but now getting gps coordinate all 0 .
That is PART of the code. Please post all of it.
I just posted all code thanks
It looks like you did not obey the above instruction.
Are you outdoors, with a clear view of the sky?
I am inside near the window . I have tested GPS in this location near the window and was getting
longitude latitude and other stuff
So it worked as expected, until you did something.
This is what happen when I added that code inside the loop. if (GPS.available()) {
when I remove this code if (GPS.available()) { ....I get altitude longitude all 0
  // Your code here
  // Check if there is new GPS data available
Connected to GPRS Network
ArduinoIoTCloudTCP::handle_ConnectMqttBroker could not connect to mqtts-sa.iot.arduino.cc:8883
ArduinoIoTCloudTCP::handle_ConnectMqttBroker 1 connection attempt at tick time 20451
ArduinoIoTCloudTCP::handle_ConnectMqttBroker 2 connection attempt at tick time 29252
ArduinoIoTCloudTCP::handle_ConnectMqttBroker 3 connection attempt at tick time 42191
ArduinoIoTCloudTCP::handle_ConnectMqttBroker 4 connection attempt at tick time 63091
ArduinoIoTCloudTCP::handle_ConnectMqttBroker 5 connection attempt at tick time 100258
ArduinoIoTCloudTCP::handle_ConnectMqttBroker 6 connection attempt at tick time 137477
Seems like at least two problems:
  • "ArduinoIoTCloudTCP::handle_ConnectMqttBroker could not connect to mqtts-sa.iot.arduino.cc:8883" means something is wrong with the connection. Does a test script connect?
  • GPS.available() never indicates new data. Maybe move the antenna until 'GPS.available() != false'
I am not getting any error anymore after this :
//the GPS_MODE_SHIELD parameter to the GPS.begin(...)
But Its seems that I don't have good GPS signal inside . Will try it outside next time .
Where is 'coordinates' defined?
I know nothing about Arduino IoT Cloud.
Looking at the code, I'd bet something in the file referenced here:
and
...work together to define and use 'coordinates'.
I don't know what this timezone code mean. do I have to add timezone somewhere in the sketch??
TimeServiceClass::setTimeZoneData offset: -18000 dst_unitl 1710054000
Is this a Bug in Arduino iot cloud or Am I doing something wrong ????
Thanks all
It doen't look like an error compared to the output in:
The line looks like it might be noting that it is applying a DaylightSavingsTime offset of -18000 seconds until the next time
DST changes on 2024 March 10
% date -ur 1710054000
Sun Mar 10 07:00:00 UTC 2024
% date -ur $(( 1710054000 - 18000 ))
Sun Mar 10 02:00:00 UTC 2024
Is -5 hours the right offset for your timezone?
I am in eastern time zone . its 11:55 am at this moment
yes its 5 hours difference from utc time
11:53:13.616 -> Seconds since Jan 1 1900 = 3910265592
11:53:13.616 -> Unix time = 1701276792
11:53:13.616 -> The UTC time is 16:53:12
11:53:24.784 -> packet received
11:53:24.784 -> Seconds since Jan 1 1900 = 3910265603
11:53:24.784 -> Unix time = 1701276803
11:53:24.784 -> The UTC time is 16:53:23
11:53:35.996 -> packet received
11:53:35.996 -> Seconds since Jan 1 1900 = 3910265615
11:53:35.996 -> Unix time = 1701276815
11:53:35.996 -> The UTC time is 16:53:35
Finally Its working with TinyGPS++ Library instead . I was able to Track my device remotely But
this option consume a lot of Data, GPS constantly keep sending coordinates through sim cart .
I don't have option to add Delay () with arduino iot platform . Delay () will crash the device . My other option is to request coordinates by sending sms text message .
