GPS Module Causing Interference in Servo Motor Control
Hello, I am implementing an Arduino code that utilizes a Gy-gps6mv2 GPS module and controls 2 servo motors. The code for the servo control and for the GPS module location acquisition work perfectly separately, however when I compile both together, the servos act uncontrollably (even executing movements greater than 180 degrees, which conventionally would not be possible), and when the GPS module is disconnected this behavior stops and they start to respond normally.
//---------------azimuth----------------------------------------------------------------
#include <QMC5883LCompass.h>
QMC5883LCompass compass;
//---------------GPS--------------------------------------------------------------------
#include <TinyGPSPlus.h>
#include <SoftwareSerial.h>
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 9600;
TinyGPSPlus gps;
SoftwareSerial ss(RXPin, TXPin);
//---------------servo------------------------------------------------------------------
#include <Servo.h>
Servo myservoH;
Servo myservoV;
  compass.init();
  compass.setCalibration(-481, 751, -673, 778, -10, 782);
  ss.begin(GPSBaud);
  myservoH.attach(9);  // Conecta o servo horizontal no pino 9
  myservoV.attach(11);  // Conecta o servo horizontal no pino 11
  //Move ambos para 90º
  myservoH.write(90);
  myservoV.write(90);  //Posição neutra vertical na verdade acontece com 80º
  if(Serial.available() > 0){
    String input = Serial.readString(); //Leando o input serial
    String function = input.substring(0, input.indexOf(",")); //extraindo o nome da função
//---------------azimuth---------------------------------------------------------------------
    if(function == "getAzimuth"){
      int azimuth = getAzimuth();
      Serial.println(azimuth);
//---------------GPS-------------------------------------------------------------------------
    else if(function == "getLocation"){
      String localizacao = getLocation();
      Serial.println(localizacao);
//---------------servo-----------------------------------------------------------------------
    else if(function == "moveServoH"){
      int p = input.substring(input.lastIndexOf(",")+1).toInt();
      int retorno = moveServoH(p);
      Serial.println(retorno);
    else if(function == "moveServoV"){
      int retorno = moveServoV(p);
  else{
    Serial.println("Função não encontrada");
int getAzimuth(){
  compass.read();
  int az = compass.getAzimuth();
  return(az);
String getLocation(){
    while(true)
      while (ss.available() > 0){
        if (gps.encode(ss.read()))
          if (gps.location.isValid() && gps.altitude.isValid())
            String Loc = String(gps.location.lat(), 6)+","+String(gps.location.lng(), 6)+","+String(gps.altitude.meters(), 2);
            return Loc;
int moveServoH(int newpos) {
  if (newpos < 0 || newpos > 180) {
    // impede que o servo seja movido para fora da faixa de 0-180 graus
    return(0);
  int pos = myservoH.read();
  if(pos>newpos) {
    for (; pos >= newpos; pos--) {
      myservoH.write(pos);
      delay(50);
  }else{
    for (; pos <= newpos; pos++) {
      delay(50);
  return(1);
int moveServoV(int newpos) {
  if (newpos < 0 || newpos > 97) {
    // impede que o servo seja movido para fora da faixa de 0-97 graus
    return(0);
  int pos = myservoV.read();
  if(pos>newpos) {
      myservoV.write(pos);
      delay(15);
  }else{
      delay(15);
  return(1);
That sounds like a not to complicated hardware problem. Please post an annotated schematic not a frizzy picture showing exactly how you have wired it. Include all connections, power, ground and power supplies. Links to technical information on the parts would also be a big help. Links to sales outlets such as aliexpress and amazon are normally useless as the needed information is not there.
Software Serial and the servo library conflict regarding the use of Timer1. Use the ServoTimer2 library instead.
this was exactly the problem, thank you very much!
