Good morning everyone!
I am working with an arduino mega 2560 board and various sensors to monitor the environment, among them I also have a gps, model Neo 6M.
All the sensors write their data to a csv file on the sd card.
This is the code I have implemented:
#include <Wire.h>
#include <MPU6050_tockn.h>
#include <SoftwareSerial.h>
#include <SdsDustSensor.h>
#include <SPI.h>
#include <SD.h>
#include <TinyGPS.h>
//define per il misuratore dB
#define SoundSensorPin A3 //this pin read the analog voltage from the sound level meter
#define VREF 5.0 //voltage on AREF pin,default:operating voltage
//variabili per sensore CO2,NH3,NO2
const int S_analog = 1023.0;
int co, nh3;
float no2;
//variabili per sensore accelerometro/giroscopio
const int MPU = 0x68; // I2C address of the MPU-6050
float AccX, AccY, AccZ, Tmp, AngX, AngY, AngZ;
float temp;
MPU6050 mpu6050(Wire);
unsigned long t1, dt;
//variabili per senosre GPS
float lat, lon;
TinyGPS gps; // create gps object
//variabili per sensore PM10 PM2.5
int rxPin = 16;
int txPin = 17;
SdsDustSensor sds(Serial2);
//variabili per SD Card
File file;
const int chipSelect = 53;
//variabili per misuratore dB
float voltageValue, dbValue;
//Serial.begin(9600); // comune a tutti
// acc/giroscopio
Wire.begin();
mpu6050.begin();
//fase di calibrazione per il giroscopio
mpu6050.calcGyroOffsets(true);
// gps
Serial.println("The GPS Received Signal:");
Serial3.begin(9600); // connect gps sensor
// pm10 pm2.5
sds.begin();
Serial2.begin(9600);
MICS6814();
Accelerometro_Giroscopio();
GPS();
//PM10_PM25();
Sound();
SD_Card();
//delay(1000);
void MICS6814() {
co = map(analogRead(A2), 0, S_analog, 1, 1000); //monossido di carbonio
nh3 = map(analogRead(A1), 0, S_analog, 1, 500); //ammoniaca
no2 = map(analogRead(A0), 0, S_analog, 5, 1000) / 100.0; //diossido di azoto
//stampo i dati sul monossido di carbonio registrato
//Serial.print("CO: ");
//Serial.print(co);
//Serial.print(",");
//Serial.print(" ppm\t ");
//stampo i dati sull'ammoniaca registrata
//Serial.print("NH3: ");
//Serial.print(nh3);
//stampo i dati sul diossido di azoto registrato
//Serial.print("NO2: ");
//Serial.print(no2);
//Serial.println("");
//Serial.print(" ppm\n");
//delay(1000);
void Accelerometro_Giroscopio() {
mpu6050.update();
dt = millis() - t1;
if (dt > 200) {
t1 = millis();
AccX = mpu6050.getAccX();
AccY = mpu6050.getAccY();
AccZ = mpu6050.getAccZ();
// angoli calcolati dal sw interno del sensore, non sono direttamente quelli misurati dal sensore
AngX = mpu6050.getAngleX();
//Serial.println(AngX);
AngY = mpu6050.getAngleY();
//Serial.println(AngY);
AngZ = mpu6050.getAngleZ();
//Serial.println(AngZ);
temp = mpu6050.getTemp();
//delay(1000);
void GPS() {
while (Serial3.available()) { // check for gps data
//Serial.print("A");
if (gps.encode(Serial3.read())) // encode gps data
//Serial.print("B");
gps.f_get_position(&lat, &lon); // get latitude and longitude
//Latitude
// Serial.print("Latitude: ");
// Serial.print(lat,6);
// Serial.print(",");
// //Longitude
// Serial.print("Longitude: ");
// Serial.println(lon,6);
//delay(1000);
void PM10_PM25() {
PmResult pm = sds.readPm();
//if (pm.isOk()) {
// stampo PM2.5
//Serial.print("PM2.5 = ");
//Serial.print(pm.pm25);
//stampo PM10
//Serial.print(" PM10 = \n");
//Serial.print(pm.pm10);
//Serial.print("\n");
//delay(1000);
void Sound() {
voltageValue = analogRead(SoundSensorPin) / 1024.0 * VREF;
dbValue = voltageValue * 50.0; //convert voltage to decibel value
//delay(1000);
void SD_Card() {
if (!SD.begin(chipSelect)) {
Serial.println("Errore");
return;
file = SD.open("datalog.csv", FILE_WRITE);
if (file) {
// faccio questo per eviatre che nel csv mi vengano stampati dei valori sballati del pm10 e pm2.5....
if (pm.isOk()) {
file.print(no2);
file.print(";");
file.print(nh3);
file.print(";");
file.print(co);
file.print(";");
file.print(pm.pm10);
file.print(";");
file.print(pm.pm25);
file.print(";");
file.print(lat,5);
file.print(";");
file.print(lon,5);
file.print(";");
file.print(AccX);
file.print(";");
file.print(AccY);
file.print(";");
file.print(AccZ);
file.print(";");
file.print(AngX);
file.print(";");
file.print(AngY);
file.print(";");
file.print(AngZ);
file.print(";");
file.print(temp);
file.print(";");
file.print(dbValue);
file.println();
file.close();
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
//delay(500);
I would like all the sensors to write to the sd card every 1 or 2 seconds.
If I put 'delay(1000)' at the end of the functions, the gps does NOT write anything to the csv file, the other sensors instead write the data correctly.
Does anyone know why?
Thank you very much.
