A disadvantage of a GPS is that it needs the GPS satellites to be visible to the antenna; with most receivers this means locating the antenna outdoors.
Have a look at using a DCF (in europe) or WWV (in North America) radio receiver. This will also keep accurate time and the radio signal is much easier to pick up indoors. There are modules available that pick up the signal but I found it cheaper to by a cheap LCD radio clock and tear it apart to pull out the module.
If you are in north America, google WWV. If in Europe google DCF. I am sure you can probably find Arduino code for these modules.
There is an arduino library that supports more than two servos.
yea i looked around for it, but there's really no info on what module could be extracted from a specific clock, or if it's possible to find one for arduino.
i'll pick up one of those atomic analog clocks and see exactly how it calibrates, watch it for a while. Then prob just hook the coil output on an analog input...
I think you want to connect the one pulse per second (1PPS) output to a digital input. I used a module from a battery operated clock, connected the wires that were going to the battery (two aaa cells) to the arduino 5v supply. Connected the 1PPS output to an arduino digital input, no other components were needed.
