hello arduino world, This problem might sound similar but i bet it is not the same. i am working on this gps tracking system where the system receives sms commands and send responds accordingly. at this point, the gsm faction of the code works so well but it does not return any gps data in the responses. i am convince its a software problem because i have tested hardware with other codes and they work just fine.
i am not exactly good at this. PLEASE HELP ME!!! I am using a arduino uno, sim900Amini and neo6 gps.
PS.
When i send the comands which requires that the system sends the gps coordinates, it responds that the information is not yet available as seen in the attach photo.
in a bit to trouble shoot, i used a code that works for gps only and with the same hardware setup i am able to receive precise location
i hope this is enough for me to get help...
here is my code
#include <SoftwareSerial.h>
#include <TinyGPS++.h>
//at this time, this code works so well but for the fact that the gps does not pic up the signal that is being received by the module
SoftwareSerial gpsSerial(4, 3); // GPS TX â 4, RX â 3
SoftwareSerial simSerial(7, 8); // SIM900A TX â 7, RX â 8
TinyGPSPlus gps;
String predefinedNumber = "************"; // Trusted number
bool sendLocationFlag = false;
String incomingData = "";
float lastLatitude = 0, lastLongitude = 0;
unsigned long lastUpdateTime = 0;
float totalDistance = 0.0;
String Seekernumber = "";
// Function prototypes
float calculateSpeed(unsigned long currentTime, float lat, float lon);
void sendSMS(String number, String message);
void checkIncomingSMS(String inputString);
gpsSerial.begin(9600);
simSerial.begin(9600);
Serial.println("System initializing...");
// Initialize GSM module
simSerial.println("AT");
simSerial.println("AT+CMGF=1\r"); // Set SMS mode to text
simSerial.println("AT+CNMI=2,2,0,0,0\r"); // Auto-show SMS
simSerial.println("AT+CMGL=\"REC UNREAD\""); // Read unread messages
Serial.println("GPS Tracker ready!");
// Process GPS data
bool newdata = false;
while (gpsSerial.available()) {
char c = gpsSerial.read(); //introduce the char c to replace the gpsserial.read() in the line below.
Serial.println(c);
if (gps.encode(c)) { newdata = true; }
// Process incoming SMS data
if (simSerial.available()) {
delay(100); // Wait for complete message
incomingData = "";
while (simSerial.available()) {
char incomingByte = simSerial.read();
incomingData += incomingByte;
delay(5);
if (incomingData.length() > 0) {
checkIncomingSMS(incomingData);
incomingData = "";
// Send location if tracking is active
if (sendLocationFlag && gps.location.isValid()) {
unsigned long currentTime = millis();
// Send location updates at 2-minute intervals
if (currentTime - lastUpdateTime >= 120000) { // 2 minutes in milliseconds
float lat = gps.location.lat();
float lon = gps.location.lng();
float speed = calculateSpeed(currentTime, lat, lon);
String gpsLink = "https://www.google.com/maps?q=" + String(lat, 6) + "," + String(lon, 6);
String message = "\nSeeker ID: " + Seekernumber + "\nLoc:" + gpsLink + "\nSpeed: " + String(speed, 2) + " km/h" + "\nTotal Distance: " + String(totalDistance, 2) + " km";
sendSMS(predefinedNumber, message);
lastUpdateTime = currentTime;
void checkIncomingSMS(String inputString) {
// Find the phone number
int index = inputString.indexOf('"') + 1;
if (index <= 0 || index >= inputString.length()) return;
inputString = inputString.substring(index);
index = inputString.indexOf('"');
Seekernumber = inputString.substring(0, index);
Serial.println("Seeker ID: " + Seekernumber);
// Find the message content
index = inputString.indexOf("\n") + 1;
String receivedSMS = inputString.substring(index);
receivedSMS.trim();
Serial.println("COMMAND: " + receivedSMS);
// Process commands (convert to uppercase for case-insensitive comparison)
receivedSMS.toUpperCase();
if (receivedSMS.indexOf("REV53") > -1) {
sendLocationFlag = true;
sendSMS(predefinedNumber, "GPS tracking activated.");
} else if (receivedSMS.indexOf("CON34") > -1) {
sendSMS(predefinedNumber, "GPS tracking deactivated.");
} else if (receivedSMS.indexOf("ST67") > -1) {
if (gps.location.isValid()) {
String gpsLink = "https://www.google.com/maps?q=" + String(gps.location.lat(), 6) + "," + String(gps.location.lng(), 6);
sendSMS(predefinedNumber, "Current Location:\n" + gpsLink);
sendSMS(predefinedNumber, "GPS location not available yet.");
float calculateSpeed(unsigned long currentTime, float lat, float lon) {
if (!gps.location.isValid() || (lastLatitude == 0 && lastLongitude == 0)) {
lastLatitude = lat;
lastLongitude = lon;
return 0.0;
float distance = TinyGPSPlus::distanceBetween(lastLatitude, lastLongitude, lat, lon) / 1000.0; // km
totalDistance += distance;
float timeElapsed = (currentTime - lastUpdateTime) / 1000.0 / 3600.0; // hours
lastLatitude = lat;
return (timeElapsed > 0) ? (distance / timeElapsed) : 0.0; // km/h
void sendSMS(String number, String message) {
Serial.println("Sending SMS to " + number);
simSerial.println("AT+CMGF=1");
simSerial.println("AT+CMGS=\"" + number + "\"");
simSerial.print(message);
simSerial.write(26); // CTRL+Z to send SMS
delay(2000);
Serial.println("SMS Sent!");
