Oops. I guess you need 90 data points to calculate every degree. You can put the data into PROGMEM so it doesn't use up valuable SRAM.
To move the needle you should draw over the old position using the background color and then draw the new position in the foreground color. You will have to re-draw the compass labels if part of them can get erased when you erase the old needle. Be sure to re-draw ONLY when the needle has changed position or you will get a lot of annoying flicker. Since you need to save the old position for erasing anyway it is easy to tell if the new position is different.
Here is the new Sine table plus the functions for looking up SineRadius and Cosineradius for any angle from 0 to 359.
#include <avr/pgmspace.h>
// Screen position of the center of the compass rose
const int ROSE_CENTER_X = 200;
const int ROSE_CENTER_Y = 64;
// For values of ROSE_RADIUS below 127 we can use 'char' to save space.
const char ROSE_RADIUS = 20;
// Putting the table of constants into FLASH/PROGMEM to save SRAM
const char SINE_TABLE[90] PROGMEM = {
// Casting the result as 'char' avoids warning messages about narrowing
char(sin(0 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(1 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(2 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(3 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(4 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(5 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(6 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(7 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(8 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(9 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(10 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(11 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(12 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(13 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(14 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(15 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(16 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(17 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(18 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(19 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(20 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(21 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(22 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(23 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(24 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(25 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(26 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(27 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(28 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(29 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(30 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(31 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(32 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(33 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(34 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(35 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(36 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(37 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(38 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(39 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(40 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(41 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(42 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(43 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(44 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(45 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(46 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(47 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(48 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(49 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(50 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(51 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(52 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(53 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(54 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(55 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(56 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(57 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(58 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(59 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(60 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(61 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(62 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(63 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(64 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(65 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(66 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(67 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(68 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(69 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(70 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(71 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(72 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(73 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(74 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(75 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(76 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(77 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(78 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(79 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(80 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(81 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(82 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(83 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(84 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(85 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(86 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(87 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(88 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5),
char(sin(89 * 2 * PI / 360.0) * ROSE_RADIUS + 0.5)
// Draw the compass pointer at an angle in degrees
void drawCompassPointer(int angle) {
int x_offset, y_offset; // The resulting offsets from the center point
// Normalize the angle to the range 0 to 359
while (angle < 0)
angle += 360;
while (angle > 359)
angle -= 360;
x_offset = getSine(angle);
y_offset = getCosine(angle);
// The actual drawing command will depend on your display library
// drawLine(ROSE_CENTER_X, ROSE_CENTER_Y, ROSE_CENTER_X + x_offset, ROSE_CENTER_Y + y_offset);
int getSine(int angle) {
// For angles less than 90, use the table directly
if (angle < 90)
return pgm_read_byte_near(&SINE_TABLE[angle]);
if (angle < 180) {
// 90 to 179: flip direction
return pgm_read_byte_near(&SINE_TABLE[179 - angle]);
if (angle < 270) {
// 180 to 269 flip sign
return -pgm_read_byte_near(&SINE_TABLE[angle - 180]);
// 270 to 359 flip sign and direction
return -pgm_read_byte_near(&SINE_TABLE[359 - angle]);
// Cosine(angle) == Sine(angle-90)
int getCosine(int angle) {
// Keep angle-90 between 0 and 359
if (angle < 90)
angle += 360;
return getSine(angle - 90);
