Hardware: Arduino nano with SSD1306 Oled. I2c connection for the display.
I tested the timing of a big sketch (CNC handwheel, modbus, click encoder for one button menu…) and recognized something strange. I set up a simplified test sketch to ask, if someone can explain this to me.
Simple sketch, prints just “Hello Test!” on that 0.96" display. In the loop() I start first setting a timer. After the print job I stop the time and print the elapsed time as well on the display. Then the display is cleared and process repeats. Sketch uses 5016 bytes (16%) of program storage space. Yes it’s fickering…but I can still read 17/18 millisecond for one code run.
Then I comment out parts of the sketch. It looks like this:
//#include <Wire.h>
#include "SSD1306Ascii.h"
#include "SSD1306AsciiWire.h"
#define I2C_ADDRESS 0x3C
#define RST_PIN -1
SSD1306AsciiWire oled;
unsigned long start, finished, elapsed;
//Wire.begin();
//oled.set400kHz();
oled.begin(&Adafruit128x64, I2C_ADDRESS);
oled.setFont(System5x7);
start = millis();
oled.setCursor(1, 4);
oled.set2X();
oled.print("Hello Test!");
finished=millis();
elapsed=finished-start;
oled.setCursor(55, 0);
oled.set2X();
oled.println(elapsed);
oled.clear();
Sketch becomes smaller. Uses now 4898 bytes storage space. Still works fine. No difference in function. BUT ! I read 12/13 millisecond for one code run. So the sketch is smaller and FASTER !? For my big sketch the speed difference is significant. I am surprised ! Commenting out <Wire.h>, Wire.begin(), oled.set400kHz() makes running the code faster with NO DIFFERNZ in display?
Am I drawing a wrong conclusion about the speed here from this test?
