Hello,
I am having trouble with my GSM shield resolving how to determine what type of call is incoming, voice or SMS. I need to differentiate between the two so I can respond accordingly. I have look at the method below and I can't figure out if the incoming data is SMS or something else. I can't find a clear description on this, Any pointers that might help.
Method checks status of call(incoming or active)
and makes authorization with specified SIM positions range
phone_number: a pointer where the tel. number string of current call will be placed
so the space for the phone number string must be reserved - see example
first_authorized_pos: initial SIM phonebook position where the authorization process
starts
last_authorized_pos: last SIM phonebook position where the authorization process
finishes
Note(important):
In case first_authorized_pos=0 and also last_authorized_pos=0
the received incoming phone number is NOT authorized at all, so every
incoming is considered as authorized (CALL_INCOM_VOICE_NOT_AUTH is returned)
return:
CALL_NONE - no call activity
CALL_INCOM_VOICE_AUTH - incoming voice - authorized
CALL_INCOM_VOICE_NOT_AUTH - incoming voice - not authorized
CALL_ACTIVE_VOICE - active voice
CALL_INCOM_DATA_AUTH - incoming data call - authorized
CALL_INCOM_DATA_NOT_AUTH - incoming data call - not authorized
CALL_ACTIVE_DATA - active data call
CALL_NO_RESPONSE - no response to the AT command
CALL_COMM_LINE_BUSY - comm line is not free
byte CallGSM::CallStatusWithAuth(char *phone_number,
byte first_authorized_pos, byte last_authorized_pos)
Regards,
StanK
