Gsm/gps sim module at commands always respond -1
Hello everyone,
I am on a project with Arduino Mega and other stuff. I read some values with sensor and send sms the data. I tried several sim modules like sim808, sim800l, sim900, siemens mc35i and all of them are sent sms correctly! But I want to check if my sim module is ready for send a sms, and then send data. And i know which AT command is usefull for me or not. But i never get any response from sim module to serial monitor.
For example if i send AT commands from arduino, i want to see "OK" or "ERROR" ob the serial monitor. I know the DEC codes etc so i would not shock if see some numbers on the monitor BUT SERIALSIM.avaiable RETURNS ONLY -1 although i send some AT commands to module! I looked for all topics, watched all videous on youtube etc about this issue. People can get some values when they try to getting response BUT i never got. I will share with you some simple code for example and what returns on Serial monitor. What it's wrong? Please help me...
Thank you everyone...
#include <SoftwareSerial.h>
SoftwareSerial cell(17, 16);
int i=0;
  cell.begin(9600);
void loop(){
  Serial.print("Loop: ");
  Serial.println(i);            //number of this loop
  cell.println("AT\r\n");
  delay(300);
  Serial.println(cell.read());
  delay(300);
  Serial.println("End loop.");
  i++;
  delay(3000);
Serial.read() return -1 if not data is available to read
try a simple test where you enter text on the keyboard and see if there is a response
// SIM900 GSM modem test - working 13 March 2022
// connect SIM900 TXD to Mega pin 19  RXD to pin 18
// AT+CGMI  returns the manufacturer's name
// AT+CGMM returns the MODEM model number
// AT+CGMR returns details of the software and model revision level
// AT+CGSN returns the MODEM's serial number
#define mySerial Serial1
  while (!Serial) {  }
  Serial.println("SIM900 test!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);//115200);//115200);
void loop() { // run over and over
  if (mySerial.available()) {
    Serial.write(mySerial.read());
  while (Serial.available()) {
    char ch;
    mySerial.write(ch=toupper(Serial.read()));
you may need to change the baudrate
Try changing that to:
Serial.println(cell.readString());
Thank you. It works. Now i should figure out how can i send AT command into codes, not by on serial monitor. I will try this :slight_smile:
Thank you, but it does not works :frowning:
