Hi I am using SIM900A and i get this error in the image below, can someone help me how to fix this? or is there any steps on how to configure a SIM900A? Thanks in advance!
#include <SoftwareSerial.h>
//Create software serial object to communicate with SIM800L
SoftwareSerial mySerial(8, 9); //SIM800L Tx & Rx is connected to Arduino #3 & #2
//Begin serial communication with Arduino and Arduino IDE (Serial Monitor)
//Begin serial communication with Arduino and SIM800L
mySerial.begin(115200);
Serial.println("Initializing...");
mySerial.println("AT"); //Once the handshake test is successful, it will back to OK
updateSerial();
mySerial.println("AT+CSQ"); //Signal quality test, value range is 0-31 , 31 is the best
updateSerial();
mySerial.println("AT+CCID"); //Read SIM information to confirm whether the SIM is plugged
updateSerial();
mySerial.println("AT+CREG?"); //Check whether it has registered in the network
updateSerial();
updateSerial();
void updateSerial()
while (Serial.available())
mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port
while(mySerial.available())
Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
and it displays in the monitor the image below. It is nonstop loop. Instead of AT commands
Because i have 15 pcs of sim900a. Some of them are working and some are not. I am also using the same code. Some of them dont display like I've posted here.
The send and receive rates have to match. Try to communicate directly with the module, from a terminal emulator. Then it will be easy to find the actual rate and match it in code.
It's possible that the different modules were set to different rates...
There is an AT command to set the baud rate, and usually another one to make it the default rate.
Anyway, the important thing is to do direct testing, don't depend on your program to operate it. Then the problem could be in your program or the device settings, but you won't know which.
That is program testing, the exact opposite of what I recommended. You should be able to do direct testing without changing hardware by loading the serial pass-through sketch. It allows you to type directly to the SIM900. This will help to troubleshoot.
