GSM SHIELD GET DATA FROM SERVER
Hello everyone,
I would like to remotely control an LED reading a string from a server (GET or POST). NO LOCALHOST
check the value of the incoming string from the server and activate the LED.
page in php performs a check on the variable and returns "1" or "'0"
The following part of the script:
#include <GSM.h>
#define PINNUMBER ""
// APN information obrained from your network provider
#define GPRS_APN "GPRS APN" // replace with your GPRS APN
#define GPRS_LOGIN "LOGIN" // replace with your GPRS login
#define GPRS_PASSWORD "PASSWORD" // replace with your GPRS password
// initialize the library instances
GSMClient client;
GPRS gprs;
GSM gsmAccess;
boolean notConnected;
char path[] = "/file.txt";
int port = 80; // port 80 is the default for HTTP
Serial.println("START");
notConnected = true;
Connect();
if(client.connect("www.mydomain.com",80)){
Serial.println("connected!");
client.print("POST http://mydomain.com/arduino/read.php?temp=121221");
client.println(" HTTP/1.1");
client.println("Host: http://mydomain.com");
client.println();
client.stop();
Serial.println("connection failed");
Serial.println("\n FAILED!\n");
void Connect(){
while(notConnected)
if(gsmAccess.begin()){
Serial.println("GSM OK");
if(gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD)){
Serial.println("GPRS OK");
notConnected = false;
Serial.println("Not connected");
I thank you in advance.
help!!!!!!!
So, what problem are you having?
Why are you not reading (and storing) the server response?
how can I intercept the server's response?
usually displays error "bad request" HTTP 302 other times FOUND.
Using client.connected(), client.available(), and client.read().
What does? Where?
Use This:
client.print("POST http://mydomain.com/prova.php?temp=121221");
client.println();
if (client.available()) {
char c = client.read();
Serial.print(c);
client.stop();
how can I intercept the text of the page php?
THIS IS RESULT:
HTTP/1.1 302 Found
Date: Thu, 11 Sep 2014 16:39:21 GMT
Server: Apache
Content-Length: 291
Connection: close
Content-Type: text/html; charset=iso-8859-1
302 Found
Found
The document has moved here.
Apache Server at *******.com Port 80 disconnecting.
I presume that you mean that you want to collect the output from the script running on the server.
    Serial.print(c);
This code should be a while statement, not an if statement, and should be in a if(client.connected()) block.
To save the data in an array is pretty simple, isn't it?
THIS IS RESULT:
HTTP/1.1 302 Found
Which means that the script is not where you think it is, but it left a forwarding address. The script was NOT run, so collecting that data in an array seems pointless.
Was there something different in the two parts you redacted?
The http:// part defines the protocol to use to talk to the host. It is NOT part of the host name OR the POST request.
