The code works fine for a day but after that it stops and when i run the serial monitor, it displays the temperature and humidity sensor value but it hangs on Starting arduino clinet in the below code. So, could someone let me know if there is an issue with the sketch or some problem with GSM Shield or Sim card ?
I am using Arduino Uno with the integrated GSM Shield.
// Adafruit_DHT library will be included
#include "DHT.h"
#include <Wire.h>
#include <SPI.h>
#include <PubSubClient.h>
#include <GSM.h>
#include <avr/pgmspace.h>
#define GPRS_APN "web.vodafone.de" // replace your GPRS APN
#define GPRS_LOGIN "" // replace with your GPRS login
#define GPRS_PASSWORD "" // replace with your GPRS password
#define PINNUMBER ""
// initialize the library instance
GSMClient gsmClient;
GPRS gprs;
GSM gsmAccess;
// URL, path & port (for example: arduino.cc)
char server[] = "xxx.xx.xx.xx";
int port = 8883; // port 80 is the default for HTTP
PubSubClient client(server, port, gsmClient);
char message_buff[100];
//declare the triggered deviation for each sensor
float temp_dev0=0.5;
float hum_dev0=0.5;
float t1,h1;
int temp_delay=1000;
int hum_delay=2000;
// You can declare the input pin here
#define DHTPIN 4
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
Serial.println(F("KY-015 test - temperature and humidity-test:"));
dht.begin();
h1 = dht.readHumidity();
t1 = dht.readTemperature();
Serial.println(F("temperature: "));
Serial.println(t1);
Serial.println(F("humidity: "));
Serial.println(h1);
while (!Serial) {
Serial.println(F("Starting Arduino web client."));
boolean notConnected = true;
while (notConnected) {
if ((gsmAccess.begin(PINNUMBER) == GSM_READY) &
(gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY)) {
notConnected = false;
Serial.println(F("Not connected"));
Serial.println(F("Connected"));
void postdata(String sensorType, String sensorId,float value, String unit){
String pubString = sensorType + "," + sensorId + "," + String(value) +"," + unit;
pubString.toCharArray(message_buff, pubString.length()+1);
if (client.connect("MQTT")) {
client.publish("test",message_buff);
void check_temperature()
delay(temp_delay);
float t = dht.readTemperature();
float temp_dev=t1-t;
if(abs(temp_dev)> abs(temp_dev0))
Serial.print(F("temperature: "));
Serial.println(t);
postdata("TemperatureSensor", "2", t , "DegreeCelsius" );
t1=t;
void check_Humidity()
delay(hum_delay);
float h = dht.readHumidity();
float hum_dev=h1-h;
if (abs(hum_dev) > abs(hum_dev0))
Serial.print(F("humidity: "));
Serial.println(h);
postdata("HumiditySensor", "1", h , "Percentage" );
h1=h;
check_Humidity();
check_temperature();
Thanks.
