Hello, I have a MultiWii PRO Flight Controller w/MTK GPS Module from hobbyking Radio Control Planes, Drones, Cars, FPV, Quadcopters and more - Hobbyking
After putting shrink wrap around the GPS's wires and flashing new firmware onto the Multiwii FC, GPS isn't working anymore.
I'd like to test it with my Arduino, but I can't find any working code or libraries for it. Could someone give me some advice which code or library I can use?
At the moment I am using TinyGPS, but get no results:
This is my GPS:
And this is the code:
#include <SoftwareSerial.h>
#include <TinyGPS.h>
/* This sample code demonstrates the normal use of a TinyGPS object.
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 3(rx) and 4(tx).
TinyGPS gps;
SoftwareSerial nss(3, 4);
static void gpsdump(TinyGPS &gps);
static bool feedgps();
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
nss.begin(4800);
Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
Serial.println("by Mikal Hart");
Serial.print("Sizeof(gpsobject) = "); Serial.println(sizeof(TinyGPS));
Serial.println("Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum");
Serial.println(" (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail");
Serial.println("--------------------------------------------------------------------------------------------------------------------------------------");
bool newdata = false;
unsigned long start = millis();
// Every second we print an update
while (millis() - start < 1000)
if (feedgps())
newdata = true;
gpsdump(gps);
float flat, flon;
unsigned long age, date, time, chars = 0;
unsigned short sentences = 0, failed = 0;
static const float LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
gps.f_get_position(&flat, &flon, &age);
print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 9, 5);
print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 5);
print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
print_date(gps);
print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 8, 2);
print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0UL : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : TinyGPS::course_to(flat, flon, 51.508131, -0.128002), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
gps.stats(&chars, &sentences, &failed);
print_int(chars, 0xFFFFFFFF, 6);
print_int(sentences, 0xFFFFFFFF, 10);
print_int(failed, 0xFFFFFFFF, 9);
char sz[32];
if (val == invalid)
strcpy(sz, "*******");
sprintf(sz, "%ld", val);
sz[len] = 0;
for (int i=strlen(sz); i<len; ++i)
sz = ' ';
- if (len > 0)*
- sz[len-1] = ' ';*
- Serial.print(sz);*
- feedgps();*
{ - char sz[32];*
- if (val == invalid)*
_ strcpy(sz, "*******");_ - sz[len] = 0;*
- if (len > 0)*
- sz[len-1] = ' ';*
- for (int i=7; i<len; ++i)*
_ sz = ' ';_
* Serial.print(sz);*
* else*
* Serial.print(val, prec);*
* int vi = abs((int)val);*
* int flen = prec + (val < 0.0 ? 2 : 1);*
* flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;*
* for (int i=flen; i<len; ++i)*
* Serial.print(" ");*
* feedgps();*
* int year;*
* byte month, day, hour, minute, second, hundredths;*
* unsigned long age;*
* gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
if (age == TinyGPS::GPS_INVALID_AGE)
_ Serial.print("****** ******* ");
* else*
* char sz[32];*
* sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d ",*
* month, day, year, hour, minute, second);*
* print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
_ feedgps();*
static void print_str(const char str, int len)
_{_
_ int slen = strlen(str);_
_ for (int i=0; i<len; ++i)_
_ Serial.print(i<slen ? str : ' ');
feedgps();
while (nss.available())
if (gps.encode(nss.read()))
return true;
return false;
Thank you,_
