hi all,
i used the code for both Arduino and processing from the link below.
i am using GY_521 module and tried to see the data on processing. although i can read data on the serial montor i see alot of worries as below.
the problem kicks in when i use processing, when i hit run a big gray window open but thing else and an error shown on the console says
arduino worrings :
C:\Users\sysadmin\Desktop\gy_521_send_serial\gy_521_send_serial.ino:156:0: warning: "MPU6050_AUX_VDDIO" redefined
#define MPU6050_AUX_VDDIO MPU6050_D7 // I2C high: 1=VDD, 0=VLOGIC
C:\Users\sysadmin\Desktop\gy_521_send_serial\gy_521_send_serial.ino:51:0: note: this is the location of the previous definition
#define MPU6050_AUX_VDDIO 0x01 // R/W
C:\Users\sysadmin\Desktop\gy_521_send_serial\gy_521_send_serial.ino:560:0: warning: "MPU6050_FIFO_EN" redefined
#define MPU6050_FIFO_EN MPU6050_D6
C:\Users\sysadmin\Desktop\gy_521_send_serial\gy_521_send_serial.ino:62:0: note: this is the location of the previous definition
#define MPU6050_FIFO_EN 0x23 // R/W
C:\Users\sysadmin\Desktop\gy_521_send_serial\gy_521_send_serial.ino:635:1: warning: 'typedef' was ignored in this declaration
typedef union accel_t_gyro_union
Sketch uses 8184 bytes (25%) of program storage space. Maximum is 32256 bytes.
Global variables use 456 bytes (22%) of dynamic memory, leaving 1592 bytes for local variables. Maximum is 2048 bytes.
processing error:
OpenGL error 1280 at bot beginDraw(): invalid enumerant
ArrayIndexOutOfBoundsException: 1
this line is highlighted when the error pops up
String portName = Serial.list()[portIndex];
thank you all
