My project is to have 3 modules connected to arduino micro. These modules are H3LIS331DL accelerometer, RTC, and an SD card.
All three components work fine together, and I was able to read and store accelerometer data to the SD card. My problem is that I need the Arduino Micro to go to sleep whenever the data read is below a certain threshold (G value), and wake up when there is a shock detected higher than 10G. However whenever the Go_to_Sleep(); function is called, my computer does not recognize the device and fails to upload.
pinMode(ConstHighPin, INPUT);
digitalWrite(ConstHighPin, HIGH);
h3lis.init();
h3lis.importPara(VAL_X_AXIS,VAL_Y_AXIS,VAL_Z_AXIS);
Serial.println(h3lis.setFullScale(H3LIS331DL_FULLSCALE_2));
Wire.begin();
//============= REGISTER CONFIG =====================
Wire.beginTransmission(Addr);// Configuring the accelerometer to operate in low power mode
Wire.write(0x20); // Select control register 1
Wire.write(0x37); // Enable X, Y, Z axis, power on mode, data output rate 50Hz
// Stop I2C Transmission
Wire.endTransmission();
Wire.write(0x22);
Wire.write(0x00);
Wire.write(0x23);
Wire.write(0x10);
Wire.write(0x24);
Wire.write(0x03);
Wire.write(0x31);
Wire.write(0x6A);
Wire.write(0x32); //Interrupt threshold config
Wire.write(0x04);
//RTC set up
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1); }
if (! rtc.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
// This line sets the RTC with an explicit date & time, for example to set
// (Year, month, day, hours, minutes, seconds)
rtc.adjust(DateTime(2019, 3, 4, 18, 30, 0));
//attachInterrupt(digitalPinToInterrupt(7),wakeup, RISING);
delay(5000);
void Go_to_sleep(){
sleep_enable();
//arduino micro interrupt pins are 0,1,2,3,7
set_sleep_mode(SLEEP_MODE_PWR_DOWN); //Set the MC to go to sleep mode
sleep_cpu(); //this command activates sleep mode
void wakeup(){
if (start == LOW){
sleep_disable(); // disable sleep mode
detachInterrupt(1); //Removes the interrupt from pin 7 (check)
start = HIGH;
