Hall Sensor on/off switch without an arduino
Hi all,
I have a project in mind, where you could turn LEDs on and off by moving a magnet close to the thingie. When it's on, touching the box with a magnet would turn the LEDs off, and on again with a second touch.
I'm pretty confident with programming, but not so much with electronics.
Looks to me that building a circuit for this with an arduino is quite straightforward.
Now, without an arduino, if I got it right, I'd have to build a flip-flop circuit. Looking at this website, it can get pretty involved. Almost daunting.
These are my pros and cons for each approach:
  • Price: without an arduino it would be cheaper, since I want to build a few of theses
  • Complexity: with an arduino I don't have any worries. But without one might be over my skill level
  • Size: The complete thing should be as small as possible (say under 5cm). It's kinda clear how small arduino boards get, so actually it feels like the flip-flop piece would take up more space (Compared to Flora)
  • Power: Because of the size limit, there's not too much space for batteries. An arduino would definitely would require more juice.
  • Parts: Without an arduino, I'd need a lot of different components I don't have at the moment.
This is just a list of educated guesses, so I'd love to hear your input, on which way to go.
This hall sensor , a battery, a resistor and an LED are all you need for simple switch. For more complicated behavior, consider programming an 8 pin ATtiny (doable with Arduino). No other external parts would be needed, and the ATtiny chip will be about the same size as a flip flop.
Have a look at reed switches. It may have enough throughput to turn on the led.
Hold on, hold on!
This is what I want to build:
LED is off. I tap the box with the magnet, hide the magnet to never be seen again, yet LED turns on, and stays on.
LED is on. I tap the box with (an other) magnet, mail the magnet to back to the store, and the LED turns off, and stays off.
So I don't think either suggestion would work without some extra stuff.
When you say "the magnet" and "another magnet" are you implying some kind of encoding?- recognition of magnet A not being the same one as magnet B, or just any magnet will work?
JimboZA:
Not at all. (Good idea, though)
Just wanted to emphasize, you'd tap then remove the magnet. I.e. the Hall sensor should work just as push button.
A standard hall effect will just turn on and off as a magnet is presented and removed.
It will not stay on.
There is a "latching" type hall effect switch though.
It turns on, if I remember correctly, with a south magnet and off by either reversing the same magnet to north or by using a seperate north magnet.
I used them once in an experimental ignition system.
Check the link here.
http://www.allegromicro.com/en/Design-Center/Technical-Documents/Hall-Effect-Sensor-IC-Publications/Latching-Switch-Hall-Effect-IC-Basics.aspx
All magnets examined to date have both a south and a north pole, although the possibility of a magnetic monopole has not been excluded!
jremington:
That was not what I meant ..........ok then how does "a seperate north face" sound to you..?? :wink:
bluejets:
Yep, that's why I said that it would simply act as a push button.
Thanks for the link about latching sensors. That's actually a good idea, and @jremington's original suggestion makes a lot more sense now.
But let's stick with the original plan. Why? The target audience is less then 1 year old, and I'm not sure that all this turning the "magic wand" this way or the other would make too much sense for him just yet.
(And I might be wrong, but let's not start a conversation about the cognitive abilities of infants. Cool guys?)
