for my project my main program will send different events to my Network Class. In that class i will transmit the data through another arduino to my computer. The communication works fine. But how should i handle my queue?
But now i would need to always check for free spaces. I thought about initializing the array with zero and reset it to zero again if i delete an struct entry.
If the behavior is strictly first-in, first-out, then an array is fine. Just use sequential items in the array, and keep track of where the first one is, and either the last one or the number of items. Or, simple add an "active" flag to each item. If it is not strictly first-in, first-out, then a linked list would likely make book-keeping easier, as it allows the list to be re-ordered whenever needed.
Yea, READ and WRITE pointers into the struct array are all you need. You do need to manage them carefully since the condition READ == WRITE can mean either FIFO Full or FIFO Empty.
Also, if you make the FIFO size a power of 2, the pointer adjustment for wrap-around is an easy bitwise AND operation. Otherwise you need a comparison.
Ok i will do it by the start!=end logic. And I use an due so the memory is no problem.
And i need it because i want to cache some data if the network is shortly not available.
why the struct with a 128 byte data array? couldn't it simply be a much larger byte array without the transmit ID which it presumably part of the header of a msg and there should be no need for the "sent" flag. wouldn't such an approach use memory more efficiently?
the same start/end indices can be to track the position of the next msg. the first byte of the msg could be the size in the buffer that need not be sent.
