#include <EEPROM.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
byte plus = 2;
byte ls_1 = A1;
byte ls_2 = A2;
byte ls_3 = A3;
byte ls_4 = A0;
byte minus = 3;
byte on_left = 6;
byte on_right = 7;
byte sen_sw = 8;
byte hyd = 5;
byte cut_mot = 10;
byte jb_1 = 11;
byte jb_2 = 12;
byte strt = 13;
byte hy_stop = 4;
byte btnPlus;
byte btnMinus;
byte count = 0;
byte target = 1;
byte in_st;
byte final_st;
byte reset1 = 9;
byte ls1;
byte ls2;
byte ls3;
byte ls4;
byte right;
byte left;
byte sen;
byte total;
uint8_t EEPROMaddress = 130;
uint8_t EEPROMaddress_1 = 120;
uint8_t EEPROMaddress_3 = 110;
byte button2_is_pressed = false;
float stored_time;
long buttonTimer = 0;
long longPressTime = 8000;
boolean buttonActive = false;
boolean buttonRes_is_pressed = true;
int senDebounceTime;
int senDebounceDelay = 50;
byte ledStateMin = LOW;
byte buttonStateMin = LOW;
byte lastButtonStateMin = LOW;
byte readingMin;
long lastDebounceTimeMin = 0;
long debounceDelayMin = 50;
pinMode(strt, INPUT);
pinMode(ls_1, INPUT);
pinMode(ls_2, INPUT);
pinMode(ls_3, INPUT);
pinMode(ls_4, INPUT);
pinMode(on_left, INPUT);
pinMode(on_right, INPUT);
pinMode(sen_sw, INPUT);
pinMode(hyd, OUTPUT);
pinMode(cut_mot, OUTPUT);
pinMode(jb_1, OUTPUT);
pinMode(jb_2, OUTPUT);
pinMode(reset1, INPUT);
pinMode(plus, INPUT);
pinMode(minus, INPUT);
pinMode(hy_stop, INPUT);
lcd.backlight();
lcd.begin(16, 2);
lcd.clear();
count = EEPROM.read(EEPROMaddress_1);
target = EEPROM.read(EEPROMaddress);
total = EEPROM.read(EEPROMaddress_3);
if(digitalRead(plus) == HIGH){
delay(50);
if(digitalRead(plus) == LOW){
target++;
count = 0;
Serial.println(target);
lcd.clear();
EEPROM.write(EEPROMaddress, target);
lcd.setCursor(0,1);
lcd.print("Tar ");
lcd.setCursor(4,1);
lcd.print(target);
if(digitalRead(minus) == HIGH){
delay(50);
if (digitalRead(minus) == LOW){
target--;
count = 0;
if(target <= 0){
target++;
lcd.clear();
lcd.setCursor(0,1);
lcd.print("Tar ");
lcd.setCursor(4,1);
lcd.print(target);
ls1 = digitalRead(ls_1);
ls2 = digitalRead(ls_2);
ls3 = digitalRead(ls_3);
ls4 = digitalRead(ls_4);
left = digitalRead(on_left);
right = digitalRead(on_right);
byte hy_strt = digitalRead(strt);
byte hyd_stop = digitalRead(hy_stop);
byte res = digitalRead(reset1);
if(hy_strt == HIGH){
digitalWrite(hyd, HIGH);
if(hyd_stop == HIGH){
digitalWrite(hyd, LOW);
byte srt = digitalRead(hyd);
if(count != target){
if((left == HIGH) && (ls2 == HIGH) && (ls4 == HIGH) && (srt == HIGH)){
digitalWrite(cut_mot, HIGH);
digitalWrite(jb_1, HIGH);
else if((right == HIGH) && (ls3 == HIGH) && (ls1 == HIGH) && (srt == HIGH)){
digitalWrite(jb_2, HIGH);
else{
digitalWrite(jb_2, LOW);
digitalWrite(cut_mot, LOW);
digitalWrite(jb_1, LOW);
else{
byte jb1 = digitalRead(jb_1);
byte jb2 = digitalRead(jb_2);
byte cut = digitalRead(cut_mot);
byte sen = digitalRead (sen_sw);
readingMin = digitalRead(sen_sw);
if (readingMin != lastButtonStateMin) {
lastDebounceTimeMin = millis();
lastButtonStateMin = readingMin;
if ((millis() - lastDebounceTimeMin) > debounceDelayMin) {
if (buttonStateMin != lastButtonStateMin) {
buttonStateMin = lastButtonStateMin;
if (buttonStateMin == HIGH) {
ledStateMin = !ledStateMin;
count++;
lcd.clear();
EEPROM.write(EEPROMaddress_1, count);
lcd.setCursor(7,1);
lcd.print("Count ");
lcd.setCursor(13,1);
lcd.print(count);
if((count == target) && (button2_is_pressed == false)){
total++;
button2_is_pressed = true;
lcd.clear();
EEPROM.write(EEPROMaddress_3, total);
if (res == HIGH){
senDebounceTime = millis();
if((millis() - senDebounceTime) > senDebounceDelay){
if ((res == LOW) && (buttonRes_is_pressed == true)){
count = 0;
buttonRes_is_pressed = false;
lcd.clear();
if((res == HIGH) && (hy_strt == HIGH) && (digitalRead(plus) == HIGH) && (digitalRead(minus) == HIGH)){
total = 0;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Batch: ");
lcd.setCursor(8,0);
lcd.print(total);
Note:
crystal: 16 Mhz
c1 & c2: 20pF ceramic capacitor
c3: 470 micro Farad capacitor
pull-up resisters: 10 kohms
current limiting resisters: 220 ohms
voltage regulator: 5v (7805)
power supply: 12v 1amp (switchable) wall wart power supply
relays: coil voltage 5v (pic attached)
