Hello,
I have looking through google and saw several answer about this related "erase button" subject, but I didn't find an answer corresponding exactly to my question.
Just a little context:
I have a "Arduino Due" which is connected to my laptop (a basic Ubuntu 12.04) on "programming port", Arduino IDE 1.5.2.
When I want to send a sketch on the Arduino's microcontroller, I need before the upload to press on the "erase button". If I didn't press on it, an error message appears saying "No device found on ttyACM0" (my arduino is rightly connected on this ttyACM0...).
If I press on the erase button and upload, then there is no problem ; The sketch is correctly upload on the Arduino.
So my question is: Do I need to press the erase button before uploading a sketch everytime ?
I thought that the IDE do it itself (software erase) ; But it seems not.
Regards,
Laurent.
The onboard ATMega16U2 is supposed to "press" the erase button for you using a FET across the switch.
You say "Arduino Due", does that means it's not an official board, maybe yours doesn't have that feature, or maybe something is broken.
Rob
Ok, but when the onboard is supposed to perform the erase operation ? When it detects the upload of a sketch ?
What do you mean by "not an official board" ? In my case, it's exactly the same that here: http://arduino.cc/en/Guide/ArduinoDue .
I don't think that something is broken, I have 2 boards and the same behaviour happens with both.
Yes, AFAIK.
You put the words 'Arduino' and 'Due' in quotes, that would normally indicate that it's not a real one.
Then I can' t explain it, maybe some quirk of running under Ubuntu.
Rob
Ok, my double quote was just a mistake.
I will try with Windows, maybe it will works. However, I noticed that the Arduino IDE 1.5 is not a stable version ... maybe a side effect, idk.
