Question: So my goal was to program the Arduino UNO so that the LED would blink as the time before the next delay would decrease. (for example, blink for 10 sec then delay 1 sec then blink for 9 sec then delay 1 sec, etc.
But the codes below are partly wrong so can someone help me to achieve my goal and tell me what I did wrong.
Blink
Turns an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to the correct LED pin independent of which board is used.
If you want to know what pin the on-board LED is connected to on your Arduino
model, check the Technical Specs of your board at:
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
modified 8 Sep 2016
by Colby Newman
This example code is in the public domain.
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(10000); // wait for 10 second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
delay(1000); // wait for a second
delay (9000);
delay (8000);
delay (7000);
delay (6000);
delay (5000);
delay (4000);
delay (3000);
delay (2000);
delay (1000);
