I am working with a SparkFun Graphical LCD with their Serial Backpack, but due to the broken firmware am using SummoningDark's replacement firmware for the backpack.
The great addition of the new firmware is XON/XOFF flow control, so it should be possible to send data to the screen "as fast as possible" without guessing where to put pauses in my drawing code.
Am I correct in thinking that XON/XOFF is simply a case of listening for data from the display, and if it sends an XOFF, I need to wait until an XON before sending any more data?
Here's the sort of thing I'm thinking - mostly based off assumptions and guesswork, so may be wrong ![]()
#include <SoftwareSerial.h>
SoftwareSerial lcd(2, 3);
lcd.begin(115200);
delay(2000);
wr(0x7C); wr(0x00); // send CMD+CLEAR
delay(2000);
// Simple loop to draw a bunch of boxes on the screen as fast as possible
// Command for drawing a line is "0x7C, 0x0F, x1, y1, x2, y2, state"
for (int i = 0; i < 10; i++) {
wr(0x7C); wr(0x0F); // box
wr(10+(10*i+i)); wr(27); // x1, y1
wr(20+(10*i+i)); wr(37); // x2, y2
wr(0x01); // state
Now, the "naive" wr() simply bashes out the bytes given as fast as it can, so very rapidly the LCD backs up and gets flooded with corruption due to missed bytes. Here I've shown a "dumb" delay put in to make the boxes draw, and this works and everything displays correctly:
// Naive wr() - bashes out bytes with a fixed delay between every byte, regardless of the screen needing time to catch up or not
void wr(byte b) {
lcd.write(b);
delay(50);
Here's a "smarter" wr(), which listens for XOFF signals (but doesn't yet respond to them in any way):
// Smarter wr() - bashes out bytes but hears data from the LCD
void wr(byte b) {
if (lcd.available()) {
byte val = lcd.read();
if (val == 0x13) { // XOFF
Serial.println("XOFF Received");
} else if (val == 0x11) { // XON
Serial.println("XON Received");
Serial.print(val);
Serial.println(" Received");
lcd.write(b);
delay(50);
The problems I'm having is that for starters I seem to be getting different values on the serial, mostly 0x93 and 0x91, even though the source for the firmware clearly seems to be sending 0x13 and 0x11 at the correct times. Another problem is that every time I actually use lcd.read() it seems to cause a lot of corruptions to appear on the screen, as if read() is causing sends. I will check for shorts and things when I am next near the spaghetti electronics, but I would have expected worse problems if I'd shorted TX to RX.
