Having difficulty with subtration of unsigned long
Hello All
I am having difficulty subtracting two unsigned long numbers. The results are coming out unexpectedly.
The attached sketch is a program for running a PWM fan. The fan part works good but I am trying to create a subroutine to tell me what speed is being called for by each of the sensors. The subroutine in question is BlinkSpeed.
The problem can be seen in the serial output. Where CurrentMillis - NextBlinkOff should = -500 but instead = 4294966796.
02:26:23.366 -> CurrentMillis = 30065
02:26:23.366 -> NextBlinkOff = 30565
02:26:23.366 -> CurrentMillis - NextBlinkOff = 4294966796
I actually have a similar code to this working but needed to do a total restructure of the program to drive the fan using a PWM library. So something went wrong here and I really have no understanding of why and when to work with unsigned longs.
[code]
#if !( ARDUINO_ARCH_NRF52840 && TARGET_NAME == ARDUINO_NANO33BLE )
  #error This code is designed to run on nRF52-based Nano-33-BLE boards using mbed-RTOS platform! Please check your Tools->Board setting.
#endif
#define _PWM_LOGLEVEL_       2
#define USING_MICROS_RESOLUTION       true    //false
// To be included only in main(), .ino with setup() to avoid `Multiple Definitions` Linker Error
#include "nRF52_MBED_Slow_PWM.h"     // https://github.com/khoih-prog/nRF52_MBED_Slow_PWM
#define HW_TIMER_INTERVAL_US      20L
uint32_t startMicros = 0;
// For mbed nRF52, you can only select NRF52 Hardware Timer NRF_TIMER_3-NRF_TIMER_4 (3 to 4)
// If you select the already-used NRF_TIMER_0-2, it'll be auto modified to use NRF_TIMER_3
// Init NRF52 timer NRF_TIMER3
NRF52_MBED_Timer ITimer(NRF_TIMER_3);
// Init nRF52_Slow_PWM, each can service 16 different ISR-based PWM channels
NRF52_MBED_Slow_PWM ISR_PWM;
const int RadPin = A0;                        // Radiator Input Thermister
const int CndPin = A1;                        // Condenser Input Thermister
const int AuxPin = A2;                        // Auxilary Input Not used at this time
const int FanPin = 9;                         // Set Fan pin
const int LED1Pin = 7;                        // Set Cooling Fan LED
const int LED2Pin = 6;                        // Set Condenser Fan LED
const int LED3Pin = 5;                        // Set Aux Fan FED
const int frequency = 10.0;                   // Set fan frequency
const int NUMBER_OF_SAMPLES = 20;             // Sent number of averages for data samples.
const unsigned long BlinkInterval = 1000;     // Blink period
// 10 bit temperature equivolents for radiator sensor Delphi 12146312
const int Rad0   = 8;      // - 20°C equivolent Sensor assumed open.
const int Rad20  = 444;    //85C
const int Rad30  = 466;    //88C
const int Rad40  = 489;    //91C
const int Rad50  = 512;    //94C
const int Rad60  = 536;    //97C
const int Rad70  = 560;    //100C
const int Rad80  = 584;    //103C
const int Rad90  = 608;    //106C
const int Rad100 = 668;    //115C This is an emergency mode either coolant is too hot or senser is shorted. Set duty cycle to 0 to activate emergency mode
// 10 bit temperature equivolents for condenser sensor Litlefuse USP7766
const int Cnd0   = 19;     //-30C Sensor Test point
const int Cnd20  = 391;    //40C
const int Cnd30  = 440;    //45C
const int Cnd40  = 489;    //50C
const int Cnd50  = 537;    //55C
const int Cnd60  = 583;    //60C
const int Cnd70  = 627;    //65C
const int Cnd80  = 668;    //70C
const int Cnd90  = 706;    //75C
const int Cnd100 = 849;    //100C Sensor Test Point
// 10 bit temperature equivolents for temp sensor Delphi 25036751
const int Aux0   = 8;      //-20C Sensor Test Point
const int Aux20  = 452;    //85C
const int Aux30  = 474;    //88C
const int Aux40  = 496;    //91C
const int Aux50  = 519;    //94C
const int Aux60  = 543;    //97C
const int Aux70  = 567;    //100C
const int Aux80  = 591;    //103C
const int Aux90  = 614;    //106C
const int Aux100 = 733;    //125C Sensor Test Point
//#define NUMBER_OF_SAMPLES
int RadVals [NUMBER_OF_SAMPLES + 1];
int CndVals [NUMBER_OF_SAMPLES + 1];
int AuxVals [NUMBER_OF_SAMPLES + 1];
int RadValAvg = 0;
int CndValAvg = 0;
int AuxValAvg = 0;
int RadSpeed = 10;
int CndSpeed = 10;
int AuxSpeed = 10;
int FanSpeed = 10;            // Set fan to 10% PWM = off
void TimerHandler()
  ISR_PWM.run();
// You can assign pins here. Be careful to select good pin to use or crash
uint32_t PWM_Pin    = FanPin;
// Channel number used to identify associated channel
int channelNum;
//float frequency = 10.0f;
void BlinkTest()                          // Blink LEDs at startup to test sensors are in range
  // Sensor one time test on startup test, Blink lights for each sensor in range.
  if (analogRead(RadPin) >= Rad0 && analogRead(RadPin) <= Rad100) {
    digitalWrite(LED1Pin, HIGH); // turn the LED on
  if (analogRead(CndPin) >= Cnd0 && analogRead(CndPin) <= Cnd100) {
    digitalWrite(LED2Pin, HIGH); // turn the LED on
    delay(500); // wait for a 1/2 second
  if (analogRead(AuxPin) >= Aux0 && analogRead(RadPin) <= Rad100) {
    digitalWrite(LED3Pin, HIGH); // turn the LED on
  digitalWrite(LED1Pin, LOW); // turn the LED off
  digitalWrite(LED2Pin, LOW); // turn the LED off
  digitalWrite(LED3Pin, LOW); // turn the LED off
void BlinkSpeed()                               // Blink LEDs to indicate speed called by each sensor
  unsigned long CurrentMillis;                  // This sets the initial time the fan PWM cycle is started
  unsigned long NextBlinkOn;                    // this sets the next time the LEDs blink on
  unsigned long NextBlinkOff;                   // this sets the next time the LEDs blink off
  int CountRadOn  = 0;    // Counter for number of radiator blinks on
  int CountCndOn  = 0;    // Counter for number of condenser blinks on
  int CountAuxOn  = 0;    // Counter for number of Aux blinks on
  int CountRadOff = 0;    // Counter for number of radiator blinks off
  int CountCndOff = 0;    // Counter for number of condenser blinks off
  int CountAuxOff = 0;    // Counter for number of Aux blinks off
  int RadBlinks   = 0;    // Initialise number of blinks based on radiator temp
  int CndBlinks   = 0;    // Initialise number of blinks based on Condenser temp
  int AuxBlinks   = 0;    // Initialise number of blinks based on Aux temp
  int MaxBlinks   = 0;    // Maximum number of blinks for all channels
  int index = 0;
  RadBlinks = RadSpeed/10;      // Number of Blinks Based on Rad Temp
  CndBlinks = CndSpeed/10;      // Number of Blinks Based on Cnd Temp
  AuxBlinks = AuxSpeed/10;      // Number of Blinks Based on Aux Temp
  MaxBlinks = max(RadBlinks, CndBlinks);
  MaxBlinks = max(MaxBlinks, AuxBlinks);
  do {
    CurrentMillis = millis();
    NextBlinkOn = CurrentMillis;
    NextBlinkOff = NextBlinkOn + BlinkInterval/2;
    Serial.print("CurrentMillis = "); Serial.print(CurrentMillis); Serial.println();
    Serial.print("NextBlinkOn = "); Serial.print(NextBlinkOn); Serial.println();
    Serial.print("CurrentMillis - NextBlinkOn = "); Serial.print(CurrentMillis - NextBlinkOn); Serial.println(); Serial.println();
    if ((signed long)(CurrentMillis - NextBlinkOn) >=0) {
      CountRadOn = CountRadOn + 1;
      CountCndOn = CountCndOn + 1;
      CountAuxOn = CountAuxOn + 1;
      Serial.print("CountRadOn = "); Serial.print(CountRadOn); Serial.println();
    if (CountRadOn <= RadBlinks) {
    if (CountCndOn <= CndBlinks) {
    if (CountAuxOn <= AuxBlinks) {
    NextBlinkOn += BlinkInterval;
    Serial.print("NextBlinkOff = "); Serial.print(NextBlinkOff); Serial.println();
    Serial.print("CurrentMillis - NextBlinkOff = "); Serial.print(CurrentMillis - NextBlinkOff); Serial.println(); Serial.println();
    if ((signed long)(CurrentMillis - NextBlinkOff) >=0) {
      CountRadOff = CountRadOff + 1;
      CountCndOff = CountCndOff + 1;
      CountAuxOff = CountAuxOff + 1;
      Serial.print("CountRadff = "); Serial.print(CountRadOff); Serial.println();
    if (CountRadOff <= RadBlinks) {
    if (CountCndOff <= CndBlinks) {
    if (CountAuxOff <= AuxBlinks) {
    NextBlinkOff += BlinkInterval;
    index = index + 1;
  } while (index < MaxBlinks);
void printData(const int& index = 0)      // Subroutine to print each pin value to the serial monitor
  PWM_LOGINFO3("Rad(", index, ") input = ", RadVals[index]);
  PWM_LOGINFO3("Cnd(", index, ") input = ", CndVals[index]);
  PWM_LOGINFO3("Aux(", index, ") input = ", AuxVals[index]);
void printAvg()  // Subroutine to print the average values to the serial monitor
  PWM_LOGWARN1("RadAvg = ", RadValAvg);
  PWM_LOGWARN1("CndAvg = ", CndValAvg);
  PWM_LOGWARN1("AuxAvg = ", AuxValAvg);
void readAnalogData(const int& index) // Subroutine to read each pin and sum them
  RadVals[index]  = analogRead(RadPin);
  CndVals[index] = analogRead(CndPin);
  AuxVals[index]  = analogRead(AuxPin);
  // sum all 5 data points
  RadValAvg += RadVals [index];
  CndValAvg+= CndVals[index];
  AuxValAvg += AuxVals [index];
void updateCheck()                  // Subroutine to do 1 cycle of reading the temperature data
  int index = 0;
  RadValAvg = 0;
  CndValAvg = 0;
  AuxValAvg = 0;
  do
    // Read 5 data points
    readAnalogData(index);          // Call the read AnalogData subroutine
    printData(index);               //Call the printData subroutine to print each reading to the serial monitor.
    index = index + 1;
  } while (index < NUMBER_OF_SAMPLES);
  // Find Average of all data points
  RadValAvg  = RadValAvg  / NUMBER_OF_SAMPLES;
  CndValAvg = CndValAvg / NUMBER_OF_SAMPLES;
  AuxValAvg  = AuxValAvg  / NUMBER_OF_SAMPLES;
  printAvg();                       //Call the printAvg function to print the average data to the serial monitor.
  // Find the speed levels required by each sensor Not only rad temperature can initiate emergency mode.
  if (RadValAvg < Rad0) RadSpeed = 0;           // Open sensor assumed fan will run in emergency mode at 100%
  if (RadValAvg < Rad20 and RadValAvg >= Rad0) RadSpeed = 10;   // 10% duty cycle = fan off
  if (RadValAvg < Rad30 and RadValAvg >= Rad20) RadSpeed = 20;
  if (RadValAvg < Rad40 and RadValAvg >= Rad30) RadSpeed = 30;
  if (RadValAvg < Rad50 and RadValAvg >= Rad40) RadSpeed = 40;
  if (RadValAvg < Rad60 and RadValAvg >= Rad50) RadSpeed = 50;
  if (RadValAvg < Rad70 and RadValAvg >= Rad60) RadSpeed = 60;
  if (RadValAvg < Rad80 and RadValAvg >= Rad70) RadSpeed = 70;
  if (RadValAvg < Rad90 and RadValAvg >= Rad80) RadSpeed = 80;
  if (RadValAvg < Rad100 and RadValAvg >= Rad90) RadSpeed = 90;
  if (RadValAvg >= Rad100) RadSpeed = 100;        // Set PWM duty cycle to 0 for emergency mode
  if (CndValAvg < Cnd20) CndSpeed = 10;   // 10% duty cycle = fan off
  if (CndValAvg < Cnd30 and CndValAvg >= Cnd20) CndSpeed = 20;
  if (CndValAvg < Cnd40 and CndValAvg >= Cnd30) CndSpeed = 30;
  if (CndValAvg < Cnd50 and CndValAvg >= Cnd40) CndSpeed = 40;
  if (CndValAvg < Cnd60 and CndValAvg >= Cnd50) CndSpeed = 50;
  if (CndValAvg >= Cnd60) CndSpeed = 60;                // Condensor is limited to 60%
  if (AuxValAvg < Aux20) AuxSpeed = 10;   // 10% duty cycle = fan off
  if (AuxValAvg < Aux30 and AuxValAvg >= Aux20) AuxSpeed = 20;
  if (AuxValAvg < Aux40 and AuxValAvg >= Aux30) AuxSpeed = 30;
  if (AuxValAvg < Aux50 and AuxValAvg >= Aux40) AuxSpeed = 40;
  if (AuxValAvg < Aux60 and AuxValAvg >= Aux50) AuxSpeed = 50;
  if (AuxValAvg < Aux70 and AuxValAvg >= Aux60) AuxSpeed = 60;
  if (AuxValAvg < Aux80 and AuxValAvg >= Aux70) AuxSpeed = 70;
  if (AuxValAvg < Aux90 and AuxValAvg >= Aux80) AuxSpeed = 80;
  if (AuxValAvg >= Aux90) AuxSpeed = 90;
  // find the sensor with the highest speed requirment or set emergency mode
  if (RadSpeed == 100|| RadSpeed == 0){
    FanSpeed = 0;                         // Emergency mode rad too hot or shorted sensor = 100, sensor open = 0
  else {
    FanSpeed = max(RadSpeed, CndSpeed); // find the highest
    FanSpeed = max(FanSpeed, AuxSpeed);  // This is the duty Cycle
  PWM_LOGWARN1("Fan Speed  = ", FanSpeed);
  //write the PWM value to the pwm output pin
  PWM_LOGWARN5("Freq = ", frequency, ", FanSpeed % = ", FanSpeed, ", Pin = ", FanPin);
  if (!ISR_PWM.modifyPWMChannel(channelNum, PWM_Pin, frequency, FanSpeed))
    Serial.print(F("modifyPWMChannel error"));
  //RadBlinks = RadSpeed/10;
  //CndBlinks = CndSpeed/10;
  //AuxBlinks = AuxSpeed/10;
#define PRINT_INTERVAL                15000L      // Interval of time ms for printing to the serial moniter
#define UPDATE_CHECK_INTERVAL_MS      15000L      // Interval of time for fan to run befor checking sensors and re adjusting fan speed
void check_status()               // Printd data to Serial Moniter
  static unsigned long print_timeout  = 0;
  static unsigned long update_timeout = 0;
  static bool LED_status = HIGH;
  // Print every PRINT_INTERVAL (15) seconds.
  if ((millis() > print_timeout) || (print_timeout == 0))
    printData();
    print_timeout = millis() + PRINT_INTERVAL;
  if ( (millis() > update_timeout) && (millis() > UPDATE_CHECK_INTERVAL_MS) )
    // Blink LED
    LED_status = !LED_status;
    digitalWrite(LED_BUILTIN, LED_status);
    updateCheck();                  // Call update check to print values to serial moniter
    BlinkSpeed();                   // Call blink test to blink out speeds
    update_timeout = millis() + UPDATE_CHECK_INTERVAL_MS;
  pinMode(RadPin, INPUT);
  pinMode(LED1Pin, OUTPUT);
  pinMode(LED2Pin, OUTPUT);
  pinMode(LED3Pin, OUTPUT);
  pinMode(FanPin, OUTPUT);
  pinMode(LED_BUILTIN, OUTPUT);
  //while (!Serial);              // comment this out prior to installation in vehical
  delay(200);
  Serial.print(F("\nStarting Car_Fan_Control using ")); Serial.println(BOARD_NAME);
  Serial.println(NRF52_MBED_SLOW_PWM_VERSION);
  digitalWrite(LED_BUILTIN, HIGH);
  // Interval in microsecs
  if (ITimer.attachInterruptInterval(HW_TIMER_INTERVAL_US, TimerHandler))
    startMicros = micros();
    Serial.print(F("Starting ITimer OK, micros() = ")); Serial.println(startMicros);
    Serial.println(F("Can't set ITimer. Select another freq. or timer"));
  channelNum = ISR_PWM.setPWM(PWM_Pin, frequency, FanSpeed);  // During setup FanSpeed will be set to initialized value of 10 = off.
  readAnalogData(0);          // Call the read AnalogData subroutine
  BlinkTest();                // Call the blink sensor BlinkTest subroutine
  check_status();
[/code]
Serial Output sample
02:26:23.366 -> CurrentMillis - NextBlinkOn = 0
02:26:23.366 ->
02:26:23.366 -> CountRadOn = 2
02:26:23.366 ->
02:26:23.366 ->
02:26:23.366 ->
02:26:23.366 -> CurrentMillis = 30090
02:26:23.366 -> NextBlinkOn = 30090
02:26:23.366 ->
02:26:23.366 -> CountRadOn = 3
02:26:23.366 ->
02:26:23.366 -> NextBlinkOff = 30590
02:26:23.420 -> CurrentMillis - NextBlinkOff = 4294966796
02:26:23.420 ->
02:26:23.420 ->
02:26:23.420 -> CurrentMillis = 30115
02:26:23.420 -> NextBlinkOn = 30115
02:26:23.420 -> CurrentMillis - NextBlinkOn = 0
02:26:23.420 ->
02:26:23.420 -> CountRadOn = 4
02:26:23.420 ->
02:26:23.420 -> NextBlinkOff = 30615
02:26:23.420 ->
What were you imaging "unsigned" means?
Hello
Are you using the datatype unsigned long, aren´t you?
Try to cast to the datatype wanted.
= positive numbers (the clue is in the name "unsigned")
= a negative number
This won't work as I suspect you want it to. Try
    if (CurrentMillis >= NextBlinkOn) {
I'm not sure. I'm an old FORTRAN programmer. But it came from a discussion on the demo program Blink without delay. But yes it should be -500 and I would have figured it might have come up as 500. Which was used effectively in my older program that didn't use the PWM library.
Yes they are in the declarations as unsigned long.
Hello mb107
Take my question and read your startpost again to get an answer. :nerd_face:
@PaulRB Same results. There was a reason unsigned long was specified in my previous program but it is beyond me. I would have thought long would have been just fine. I do notice the variable are declared as unsigned long but the the statement places a signed long in parenthesis inside the "if" statement. I cant figure out what that for. I thought it was some kind of conversion.
@paulpaulson
When you say cast to the data type, are you saying change the declarations maybe to long.
@paulpaulson Sorry I'm lost?
No, that's not how it rolls over.
Whatever the reason may be, as long as it's an unsigned long, there won't be negative values. I'm sure you can figure out the arithmetic to do this without negative values, yes?
@anon35827816 I am thinking that maybe I have a logic problem and that the numbers I should be generating should produce a positive and then the issue goes away. But its 3:30AM here so its time for me to go to bed.
Thanks to all who relied.
Before you go to sleep, read up on signed vs unsigned data types
You’ll wake up with the solution.
Yes, that would be my suggestion.
Tomorrow with a fresh pair of eyes and a new caffeine injection I'm sure it'll all make much more sense :slight_smile:
    if ((signed long)(CurrentMillis - NextBlinkOn) >= 0) {
This is not how you do millis timing, the conventional form would be something like this
    if ((CurrentMillis - previousBlinkOn >= blinkOnTime) {
where previousBlinkOn is set to whatever CurrentMillis was the last time the if statement was true, and blinkOnTIme is the time interval.
1. You have given +30065 (x1) and +30565 (x2) to the UNO and have asked it to compute x1 - x2. You are expecting -500 (x3 = x1 - x2).
2. Serial Monitor shows you 4294966796 which makes you believing that the UNO has done wrong calculation which is not true at all!
3. UNO has done the right job and has found -500 (x3) for you. It is the print() method (which always shows 32-bit value) that has transformed -500 (0xFE0C into FFFFFE0C (due to unsigned data type of the result) and has displayed 4294966796.
4. Moreover, as a user, one must have some idea about the nature of the result of his arithmetic operation. since x1 < x2, the result will be negative; therefore, the user must declare a variable with proper data type (long) to hold the negative result.
5. Observe the following codes which shows: 4294966796
  unsigned long x1 = 30065; // x1 = 0x7571
  unsigned long x2 = 30565; // x2 = 0x7765
  unsigned long t = x1 - x2; //x1 - x1 = -500 = FE0C
  Serial.println(t, DEC); //t = (FFFF)FE0C; shows: 4294966796
  //or Serial.println((x1-x2), DEC); //(x1-x2)  = (FFFF)FE0C shows: 4294966796
void loop() {}
6. Observe the following codes which shows: -500
  Serial.println(t, DEC); //t = (FFFF)FE0C; shows: -500
  //or Serial.println((long)(x1-x2), DEC); //(x1-X2) = (FFFF)FE0C; shows: -500
void loop() {}
7. When t is declared as unsigned long in Step-5, the compiler populates the upper 16-bit of t with the MSBit (which is 1, the sign bit) of lower 16-bit (FE0C). As a result, t holds FFFFFE0C and prints the corresponding positive value which is 4294966796.
8. When t is declared as signed long in Step-6, the compiler still populates the upper 16-bit of t with the MSBit (which is 1, the sign bit) of lower 16-bit (FE0C). As a result, t holds FFFFFE0C and prints the corresponding negative value which is -500.
9. Because of signed data type (Step-8), the print() method takes the value of t in 2's complement form; where, the MSBit carries negative positional value (-1x2^31 = - 2,147,483,648). All other bits (b30, ...., b0) carries positive positional values (7FFFFE0C = 268434956). As a result, we get: - 2,147,483,648 + 2147483148 = -500.
@PaulRB @anon35827816 @lastchancename @david_2018 @paulpaulson @GolamMostafa
Thanks to everyone who replied.
So I'm concluding that there is some logic in my program that is causing a negative number which should be positive.
I have also concluded that I don't even need to use this structure in this coda as I can now use a blink with delay statements since I have taken the out of the code that generated the PWM signal for the original fan program I was using.
But I would certainly like to understand what is going on with the if statement if ((signed long)(CurrentMillis - NextBlinkOn) >= 0) {
This seems to be a far more complex statement then the if as presented in the Arduino reference library. And this is the first time I'm stepping out of the structure as presented in the reference library. And I do need to use this structure for boards that don't have a PWM library yet.
Will give it a try. But I still have a question on why do I have to use signed or unsigned? Why cant I just use long?
I knew that 2's compliment had something to do with this. And it would make sense. But its been about 30 years since I played with it.
Thanks
