Having strange issue sending Char array through SMS on mkr 1400
I'm doing a project where I am sending GPS data through SMS. I'm having an issue sending a char array on SMS. I'm sending two char arrays; one is a prewritten statement, and one is the line of GPS information. The prewritten one is being sent normally; however, the GPS data is sent in multiple messages, and one char is added to the previous message. Even when I use strcat() to put them in one array, I get the exact same issue. Attached is my code and a screenshot of the messages. :pray:
// GET $GPRMC LINE FROM GPS-module.
// USING: MKRGSM1400 & ADAFRUIT ULTIMATE GPS BREAKOUT v3
 * GPS TEST
 * MKRGSM1400
#include <Arduino.h>
// Include the GSM library
#include <MKRGSM.h>
#include "arduino_secrets.h"
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
// PIN Number
const char PINNUMBER[] = "0000";
// initialize the library instance
GSM gsmAccess;
GSM_SMS sms;
#define SerialGPS Serial1  // RX&TX PINS
#define CHECK_INTERVAL 5  //seconds.
//VARS
 char remoteNum[20]= "7326749230";
int buttonState = 0;
char txtMsg[300]= "I need help at : \n";
unsigned long previousTest;
bool mGPS_got_line = false, mGPS_paused = false;
uint8_t mGPS_idx=0;
char mGPS_TempLine[120];
  Serial.begin(9600); //USB
  SerialGPS.begin(9600); //TEST GPS.
  while(!Serial) { ; } //WAIT FOR SERIAL USB.
  Serial.print("\nTEST SOMETHING\n\n");
  pinMode(6, INPUT);
  bool connected = false;
   while (!connected) {
    if (gsmAccess.begin(PINNUMBER) == GSM_READY) {
      connected = true;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
if (millis() - previousTest >= CHECK_INTERVAL*1000UL)
  previousTest = millis();
  Serial.print("\n\nGET NEW LINE\n\n");
  if (mGPS_paused) mGPS_paused = false;
char mGPS = 0;
if ((SerialGPS.available() > 0) && !mGPS_got_line && !mGPS_paused)
  mGPS = SerialGPS.read();
  //Serial.write(mGPS);   //DEBUG
  if (mGPS == '\n')
    mGPS_TempLine[mGPS_idx] = 0; mGPS_idx = 0; mGPS_got_line = true;
     mGPS_TempLine[mGPS_idx++] = mGPS;
     if (mGPS_idx >= 120) mGPS_idx = 119; //dont overflow.
if (mGPS_got_line)
  if (strstr(mGPS_TempLine, "$GPRMC"))
    Serial.print("-->");Serial.println(mGPS_TempLine);
    //DO SOMETHING WITH THE LINE.
    //done parsed.
    mGPS_paused = true; mGPS_got_line = false; //Reset to get a new after paused has been reset.
    mGPS_got_line = false; //wrong line not GPRMC. get another.
  Serial.print(dest);
  sms.beginSMS(remoteNum);
sms.print(txtMsg);
sms.print(mGPS_TempLine);
    delay(20000);
   sms.endSMS();
buttonState = digitalRead(6);
  // check if the pushbutton is pressed. If it is, the buttonState is HIGH:
    if ((buttonState == HIGH) && (strstr(mGPS_TempLine, "$GPRMC")))
  // if ((buttonState == HIGH) && (gsmAccess.begin(PINNUMBER) == GSM_READY) && (strstr(mGPS_TempLine, "$GPRMC")))
//Serial.print("pressed");
//  sms.beginSMS(remoteNum);
//  sms.print(dest);
//Serial.print("ok");
//Serial.print("passed");
//  } else if ((buttonState == HIGH)&& (!(gsmAccess.begin(PINNUMBER) == GSM_READY))) {
//     // turn LED on:
//    digitalWrite(7, HIGH);
} //END LOOP
i can't dive into your code, makin'me dizzy..
If you presss CMD+T (Mac) in the IDE the code is formatted.
Try to Serial.print() your output first. After it's correct, do the sms.print().
