haw can arduino read a string ?
hello
i can't understand how arduino read a string ? in this code i the led is always on !
int rLed = 12;
   Serial.begin (9600);
   pinMode(rLed, OUTPUT);
   digitalWrite(rLed, LOW);
   while (Serial.available()) {
    // get the new byte:
    char inChar = (char)Serial.read();
    // add it to the inputString:
    inputString += inChar;
    if(inputString == "on"){
       digitalWrite(rLed, HIGH);
   if(inputString == "off"){
See Serial input basics
Hint: have you considered subtracting anything from the string?
Where is inputString defined? And if it is defined as a String object, get rid of it and use a char array instead. It will save you a noticeable amount of memory.
input string is defined as a string
sawi:
Since your shift key appears to be broken, how can we know what you are talking about? What happens when you receive "on"? What happens when the next letter arrives? What is in inputString then?
Very basic serial code to control the arduino LED.
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
int ledPin = 13;
String readString;
  pinMode(ledPin, OUTPUT);
  Serial.println("serial on/off test 0021"); // so I can keep track
    delay(3);
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    if (readString == "on")
      digitalWrite(ledPin, HIGH);
      Serial.println("LED ON");
    if (readString == "off")
      digitalWrite(ledPin, LOW);
      Serial.println("LED OFF");
    readString="";
it works very well !
thank you
