HC 06 NO RESPOND ON AT COMMANDS
PROBLEM:
I am using arduino UNO R3 and HC 06 BLUETOOTH MODULE
  1. WHEN I TYPE "AT" COMMANDS ON SERIAL MONITOR NO RESPOND "OK".
HOW WILL I KNOW THAT HC 06 BLUETOOTH MODULE IS STILL OK?
Arduino UNO R3 - HC 06
0 - RX --> Divider --> TX
1 - TX ---------------> RX
VCC 5V ----------------> VCC
code:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(0, 1); // RX, TX
Serial.println("Enter AT Commands:");
mySerial.begin(9600);
void loop() // run over and over
if (mySerial.available()){
Serial.write(mySerial.read()); //Receive from hc06
if (Serial.available()){
mySerial.write(Serial.read()); //send to hc06
GRND ----------------> GRND
You are using the hardware serial ports D0,D1 but are running the bluetooth module under software serial. I don't know what pair of pins you use for software serial, there is probably something in the library examples, but it isn't D0,D1.
what should I do? I'm using Arduino UNO R3.
try pins 2,3, or use a programme which does the job with hardware serial
