StreetKing17's RX code
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
int MainLights = 13;
int EmergLight = 12;
int Motor1Forw = 11;
int Motor1Rev = 10;
int Motor2Forw = 9;
int Motor2Rev = 8;
int WaterUp = 7;
int WaterDown = 6;
mySerial.begin(9600);
pinMode(MainLights, OUTPUT);
pinMode(EmergLight, OUTPUT);
pinMode(Motor1Forw, OUTPUT);
pinMode(Motor1Rev, OUTPUT);
pinMode(Motor2Forw, OUTPUT);
pinMode(Motor2Rev, OUTPUT);
pinMode(WaterUp, OUTPUT);
pinMode(WaterDown, OUTPUT);
if(mySerial.available() > 1){
int input = mySerial.parseInt();//read serial input and convert to integer (-32,768 to 32,767)
if(input == 00){//if on code is received
digitalWrite(MainLights, HIGH);//turn LED on
if(input == 11){//if off code is received
digitalWrite(MainLights, LOW);//turn LED off
if(input == 22){//if off code is received
digitalWrite(EmergLight, HIGH);//turn LED on
if(input == 33){//if off code is received
digitalWrite(EmergLight, LOW);//turn LED off
if(input == 44){//if on code is received
digitalWrite(Motor1Forw, HIGH);//turn LED on
if(input == 55){//if off code is received
digitalWrite(Motor1Forw, LOW);//turn LED off
if(input == 66){//if on code is received
digitalWrite(Motor1Rev, HIGH);//turn LED on
if(input == 77){//if off code is received
digitalWrite(Motor1Rev, LOW);//turn LED off
if(input == 88){//if on code is received
digitalWrite(Motor2Forw, HIGH);//turn LED on
if(input == 99){//if off code is received
digitalWrite(Motor2Forw, LOW);//turn LED off
if(input == 100){//if on code is received
digitalWrite(Motor2Rev, HIGH);//turn LED on
if(input == 200){//if off code is received
digitalWrite(Motor2Rev, LOW);//turn LED off
if(input == 300){//if on code is received
digitalWrite(WaterUp, HIGH);//turn LED on
if(input == 400){//if off code is received
digitalWrite(WaterUp, LOW);//turn LED off
if(input == 500){//if on code is received
digitalWrite(WaterDown, HIGH);//turn LED on
if(input == 600){//if off code is received
digitalWrite(WaterDown, LOW);//turn LED off
mySerial.flush();//clear the serial buffer for unwanted inputs
delay(30);//delay little for better serial communication
StreetKing17's TX code
SoftwareSerial mySerial(2, 3); //RX, TX
int MainLights = 6;
int EmergLight = 7;
int Motor1Forw = 8;
int Motor1Rev = 9;
int Motor2Forw = 10;
int Motor2Rev = 11;
int WaterUp = 12;
int WaterDown = 13;
boolean onOff1 = 0;
boolean onOff2 = 0;
boolean onOff3 = 0;
boolean onOff4 = 0;
boolean onOff5 = 0;
boolean onOff6 = 0;
boolean onOff7 = 0;
boolean onOff8 = 0;
pinMode(MainLights, INPUT);
pinMode(EmergLight, INPUT);
pinMode(Motor1Forw, INPUT);
pinMode(Motor1Rev, INPUT);
pinMode(Motor2Forw, INPUT);
pinMode(Motor2Rev, INPUT);
pinMode(WaterUp, INPUT);
pinMode(WaterDown, INPUT);
int buttonState1 = digitalRead(MainLights);//read button state
if(buttonState1 == 1){//if button is down
mySerial.println(00);//send unique code to the receiver to turn on. In this case 1111
onOff1 = 1;//set boolean to 1
if(buttonState1 == 0 && onOff1 == 1){//Verifier to send off signal once
mySerial.println(11);//send unique code to the receiver to turn off. In this case 0000
delay(40);//delay little for better serial communication
int buttonState2 = digitalRead(EmergLight);
if(buttonState2 == 1){//if button is down
mySerial.println(22);//send unique code to the receiver to turn on. In this case 1111
onOff2 = 1;//set boolean to 1
if(buttonState2 == 0 && onOff2 == 1){//Verifier to send off signal once
mySerial.println(33);//send unique code to the receiver to turn off. In this case 0000
int buttonState3 = digitalRead(Motor1Forw);
if(buttonState3 == 1){//if button is down
mySerial.println(44);//send unique code to the receiver to turn on. In this case 1111
onOff3 = 1;//set boolean to 1
if(buttonState3 == 0 && onOff3 == 1){//Verifier to send off signal once
mySerial.println(55);//send unique code to the receiver to turn off. In this case 0000
int buttonState4 = digitalRead(Motor1Rev);
if(buttonState4 == 1){//if button is down
mySerial.println(66);//send unique code to the receiver to turn on. In this case 1111
onOff4 = 1;//set boolean to 1
if(buttonState4 == 0 && onOff4 == 1){//Verifier to send off signal once
mySerial.println(77);//send unique code to the receiver to turn off. In this case 0000
int buttonState5 = digitalRead(Motor2Forw);
if(buttonState5 == 1){//if button is down
mySerial.println(88);//send unique code to the receiver to turn on. In this case 1111
onOff5 = 1;//set boolean to 1
if(buttonState5 == 0 && onOff5 == 1){//Verifier to send off signal once
mySerial.println(99);//send unique code to the receiver to turn off. In this case 0000
int buttonState6 = digitalRead(Motor2Rev);
if(buttonState6 == 1){//if button is down
mySerial.println(100);//send unique code to the receiver to turn on. In this case 1111
onOff6 = 1;//set boolean to 1
if(buttonState6 == 0 && onOff6 == 1){//Verifier to send off signal once
mySerial.println(200);//send unique code to the receiver to turn off. In this case 0000
int buttonState7 = digitalRead(WaterUp);
if(buttonState7 == 1){//if button is down
mySerial.println(300);//send unique code to the receiver to turn on. In this case 1111
onOff7 = 1;//set boolean to 1
if(buttonState7 == 0 && onOff7 == 1){//Verifier to send off signal once
mySerial.println(400);//send unique code to the receiver to turn off. In this case 0000
int buttonState8 = digitalRead(WaterDown);
if(buttonState8 == 1){//if button is down
mySerial.println(500);//send unique code to the receiver to turn on. In this case 1111
onOff8 = 1;//set boolean to 1
if(buttonState8 == 0 && onOff8 == 1){//Verifier to send off signal once
mySerial.println(600);//send unique code to the receiver to turn off. In this case 0000
You are running into the blocking behavior/timeout of Serial.parseInt(). You are better to change the entire approach to send and receive following the methods of Robin2's Serial Basics Tutorial.
Do not use delay on the receiving code, and let the TX code control the timing.
You are not managing the boolean control values correctly in the TX code. You never set them back to 0, and consequently you are continually sending the turnoff message every pass through loop.
You are not using the Serial monitor, so the HC12's can be connected to the hardware serial pins 0 and 1 after the code is loaded. It can be faster and more reliable than software serial. Remember to cross connect the module RX to the arduino TX pin and the module TX to the arduino RX pin.
