I am really new with Arduino and I am working with an HC-SR04 Sensor. The project I am working with has LED lights blinking when the sensor is close to someone. I found a code that works perfect except that the lights blink before someone is close, but blink faster when someone is closer to the sensor. I would like the Lights to blink only when someone is close to the sensor and was wondering if there was a way to edit the code for this?
also if I want to increase the distance the sensor reads what area of this code would I work with to increase it?
// For complete project details, visit: Arduino with PIR Motion Sensor | Random Nerd Tutorials
// Modified by Rui Santos based on PIR sensor by Limor Fried
/* HC-SR04 Sensor
https://www.dealextreme.com/p/hc-sr04-ultrasonic-sensor-distance-measuring-module-133696
This sketch reads a HC-SR04 ultrasonic rangefinder and returns the
distance to the closest object in range. To do this, it sends a pulse
to the sensor to initiate a reading, then listens for a pulse
to return. The length of the returning pulse is proportional to
the distance of the object from the sensor.
The circuit:
- VCC connection of the sensor attached to +5V
- GND connection of the sensor attached to ground
- TRIG connection of the sensor attached to digital pin 12
- ECHO connection of the sensor attached to digital pin 12
Original code for Ping))) example was created by David A. Mellis
Adapted for HC-SR04 by Tautvidas Sipavicius
This example code is in the public domain.
class Blinker {
byte pin;
int BPM = 0;
byte lubDub = 0;
unsigned long lubDubMs[4];
unsigned long lubDubStartMs = 0;
public:
Blinker(byte pin) : pin(pin) {}
pinMode(pin, OUTPUT);
if(BPM == 0) return;
if(millis() - lubDubStartMs < lubDubMs[lubDub]) return;
lubDub = (lubDub + 1) % 4;
digitalWrite(pin, (lubDub % 2)==0 ? HIGH : LOW);
lubDubStartMs = millis();
void off() {
BPM = 0;
digitalWrite(pin, LOW);
void setRate(int BPMp) {
if(BPMp == BPM) return; // no change
if(BPMp == 0) { // dead
off();
return;
BPM = BPMp;
if(BPM > 800) { // also dead, but we'll soldier on ![]()
// this caps our millisecond period to 100ms
BPM = 800;
unsigned long totalMs = 60L * 1000L / BPM;
// I'm not sure how long a 'lub dub' should be. I'll go with 150ms for the 'lub', 100ms for the 'dub',
// and 150ms in between. There should be a pause of (say) 250 after the 'dub'.
// the problem is that this may excced our maximum rate. If it does, we have to compress things ![]()
// our usual cycle is 600ms, so things start to compress after 100PBM, which seems reasonable
// if the 'compression' > 1, then no compression is needed. We just let the gap after the 'dub'
// take all the slack.
float compress = (float)totalMs / (float)(150 + 150 + 100 + 200);
if(compress > 1) compress = 1;
lubDubMs[0] = 100 * compress;
lubDubMs[1] = 100 * compress;
lubDubMs[2] = 50 * compress;
lubDubMs[3] = totalMs - lubDubMs[0] - lubDubMs[1] - lubDubMs[2];
const int trigPin = 12;
const int echoPin = 12;
Blinker led(13); // Blinker on pin 13
unsigned long lastPingMs100;
// initialize serial communication:
led.setup();
led.loop();
if(millis()/100 != lastPingMs100) {
ping();
lastPingMs100 = millis() /100;
void ping()
// establish variables for duration of the ping,
// and the distance result in inches and centimeters:
long duration, inches, cm;
// The sensor is triggered by a HIGH pulse of 10 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(trigPin, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(0);
digitalWrite(trigPin, HIGH);
delayMicroseconds(80);
// Read the signal from the sensor: a HIGH pulse whose
// duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(echoPin, INPUT);
duration = pulseIn(echoPin, HIGH);
// convert the time into a distance
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
// set led rate. You could also compute it using map()
if(inches < 612) led.setRate(120);
else if(inches < 3012) led.setRate(60);
else led.off();
long microsecondsToInches(long microseconds)
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 800 / 2;
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
