Hello guys, i am facing a problem when i tried using the servo and the ultrasonic together. It is giving me only 1 value all the time.
// Example NewPing library sketch that does a ping about 20 times per second.
#include <NewPing.h>
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
#define MAX_DISTANCE 400 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
#define TRIGGER_PIN 51
#define ECHO_PIN 49
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
myservo.attach(53);
Serial.begin(9600); // Open serial monitor at 115200 baud to see ping results.
myservo.write(30);
unsigned int uS = sonar.ping();
delay(50); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
uS;// Send ping, get ping time in microseconds (uS).
Serial.print("Ping: ");
Serial.print(uS / US_ROUNDTRIP_CM); // Convert ping time to distance in cm and print result (0 = outside set distance range)
Serial.println("cm1");
delay(2000);
myservo.write(75);
uS;
Serial.println("cm2");
delay(2000);
myservo.write(130);
uS;
Serial.println("cm3");
delay(2000);
