Hc-sr04 ultrasonic sensor gives completely wrong distances
Hello!
I have a hc-sr04 sensor mounted on a rotating platform. at first all worked just fine, but at some point I started getting completely wrong readings from the sensor, like:
At -10 degrees nearest object within: 377 cm
At -11 degrees Radar is out of range
At -12 degrees nearest object within: 373 cm
At -13 degrees Radar is out of range
Alert!! at -13 degrees object within 63 cm. Lunching!
At -14 degrees nearest object within: 397 cm
At -15 degrees Radar is out of range
At -16 degrees Radar is out of range
At -17 degrees Radar is out of range
Alert!! at -17 degrees object within 57 cm. Lunching!
At -15 degrees nearest object within: 388 cm
At -14 degrees Radar is out of range
while scanning a plain wall within 375+- cm away.
The platform rotates using a stepper motor, and if the ultrasonic sensor detects an object under 160 cm, a servo motor rotates and releases a rubber band.
because initially everything worked ok, and suddenly I started getting wrong readings, Im not sure what went wrong. (separately, the ultrasonic sensor has no problems).
Thank you very much!
#define ECHO 13        // Pin received echo pulse
#define TRIGGER 10     // Pin sends shot pulse
float distance; // the distance in cms
unsigned long previousMicros = 0; // will sotre last time TRIGGER was updated
long onTime = 10; //microseconds of on-time
long offTime = 2; //microseconds of off-time
unsigned long previousMillis = 0; //will store last time viewTime was updated
int triggerState = LOW; // triggerState used to set it up
float duration;
unsigned long prevPrint = 0; // used to determine wheather to print
#include <AccelStepper.h>
float loc = 0;
float deg = 0;
int lastDeg = -1; //used to make sure not to print twice for same deg
int  wires = 4; // Symbolic names for number of pins, here 4 pins
AccelStepper stepper(wires,4,6,5,7);
float degMax = 9; //deg of range each side
float locMax = degMax*(4076/360); // 4076 steps. each deg 11.32 steps
String way = "clkWise";
#include <Servo.h>
int servoPin = 9;
int servoPos = 0;
Servo trigger;
  pinMode(ECHO, INPUT);
  pinMode(TRIGGER, OUTPUT);
  stepper.setMaxSpeed(1.0);
  stepper.setSpeed(1.0);
  stepper.setAcceleration(5.0);
  stepper.setCurrentPosition(0);
  trigger.attach(servoPin);
  trigger.write(0);
  loc = stepper.currentPosition();
  deg = loc*0.0883219;
  if(way.equals("clkWise") && loc < locMax) {
    stepper.move(locMax*2); //clockwise
    stepper.run();
  else if(way.equals("clkWise")&& loc >= locMax){
    way = "cntClkWise";
    stepper.move(-locMax*2); //counterclockwise
    stepper.run();
  else if(way.equals("cntClkWise") && loc > -locMax) {
    stepper.run();
  else if(way.equals("cntClkWise")&& loc <= -locMax){
    way = "clkWise";
    stepper.run();
  // check to see if it's time to change the state of the TRIGGER
  unsigned long currentMicros = micros();
  if((triggerState == LOW) && (currentMicros - previousMicros >= offTime)) {
     triggerState = HIGH; // turn it on
     previousMicros = currentMicros; // remember the time
     digitalWrite(TRIGGER, triggerState); // update the actual trigger
  else if((triggerState == HIGH) && (currentMicros - previousMicros >= onTime)) {
       triggerState = LOW; // turn it off
  duration = pulseIn(ECHO,HIGH);
  distance = ((duration*0.034)/2);
  if (distance <= 160){
      Serial.print("Alert!! at ");
      Serial.print(int(deg));
      Serial.print(" degrees object within ");
      Serial.print(int(distance));
      Serial.println(" cm. Lunching!");
      Lunching();
  else if ((currentMicros - prevPrint >= pow(10,6)) && (int(deg) != lastDeg)) { //print only once a second and once for each deg, as long as radar is clear
    if ((distance >= 400 || distance <= 2)){
      Serial.print("At ");
      Serial.println(" degrees Radar is out of range");
    else {
      Serial.print(" degrees nearest object within: ");
      Serial.println(" cm");
    prevPrint = currentMicros;
    lastDeg = int(deg); //update lastDeg
void Lunching() {
  stepper.stop();
  servoPos = 70;
  trigger.write(servoPos);
  trigger.write(0);
  //Waiting for reload to resume scanning
  Serial.println("Rubbr band successfully lunched. resume scanning?");
  while(Serial.available() == 0) {
  Serial.println("Resuming");
Hi, @jackssparrow
Welcome to the forum.
Can I suggest you try the NewPing library, it does all the calculating for you.
Can I suggest you try an example from NewPing?
It looks like you are doing a lot in your code.
Have you developed your code in stages?
If so, you should have a code that JUST tests the ultra-sonic sensor.
Thanks... Tom.. :smiley: :+1: :coffee: :australia:
I know my code is a mess, its my first time using Arduino or actually coding haha.
I'll check the NewPing
thanks!
I think you should add in your definitions your max ping distance, firstly. Secondly, do you mean "launching"?
As @TomGeorge said, try working with the NewPing library. It is a great library that will make you proficient in using these sensors in no time. Then, add more after the sensing part is working well.
Good luck.
