I am using New ping library 1.6 beta. whenever i verify my code for arduino due, it gives following errors, whereas with arduino mega, it is fine. please help me out.
my code
// Example NewPing library sketch that does a ping about 20 times per second.
#include <NewPing.h>
#define TRIGGER_PIN 12 // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN 11 // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
delay(50); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
Serial.print("Ping: ");
Serial.print(sonar.ping_cm()); // Send ping, get distance in cm and print result (0 = outside set distance range)
Serial.println("cm");
My errors with arduino due
C:\Users\DeAdLy_pHaNt0mS\Documents\Arduino\libraries\NewPing\NewPing.cpp: In constructor 'NewPing::NewPing(uint8_t, uint8_t, unsigned int)':
C:\Users\DeAdLy_pHaNt0mS\Documents\Arduino\libraries\NewPing\NewPing.cpp:21:17: error: cannot convert 'RwReg* {aka volatile long unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
_triggerOutput = portOutputRegister(digitalPinToPort(trigger_pin)); // Get the output port register for the trigger pin.
C:\Users\DeAdLy_pHaNt0mS\Documents\Arduino\libraries\NewPing\NewPing.cpp:22:13: error: cannot convert 'RoReg* {aka volatile long unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
_echoInput = portInputRegister(digitalPinToPort(echo_pin)); // Get the input port register for the echo pin.
C:\Users\DeAdLy_pHaNt0mS\Documents\Arduino\libraries\NewPing\NewPing.cpp:24:75: error: 'portModeRegister' was not declared in this scope
_triggerMode = (uint8_t *) portModeRegister(digitalPinToPort(trigger_pin)); // Get the port mode register for the trigger pin.
Error compiling.
