Only way to turn letters upside down would to use Customer characters, and there is only memory for 8 of them, so unless you only have 8 different chars on the LCD it won't work.
mikehiow:
Is it possible to flip what is displayed on the screen, so it is "upside down"?
The screen I want to use has the header pins along the top - due to space constraints, I need them along the bottom. Can it be done?
Failing that, does anyone know of a 20x4 screen with a negative red backlight that doesn't have loads of PCB sticking out top and bottom?
Can't quite understand the red backlight display question. Do you mean the PCB needs to be flush with the frame of the display metal frame? I wish to find that too but not really easy to find.
