HD44780 LCD hookup help.
Hey all i am in need of some help hooking up my HD44780 20*4 LCD.
I currently have it wired as so on the HD44780:
Pin
1 Vss GND
2 Vcc 5V
3 Vee GND
4 RS PD4 on AVR
5 RW GND
6 E PD5 on AVR
7 DB0 not connected
8 DB1 not connected
9 DB2 not connected
10 DB3 not connected
11 DB4 PD0 on AVR
12 DB5 PD1 on AVR
13 DB6 PD2 on AVR
14 DB7 PD3 on AVR
15 A +5V with 330[ch937]
16 K GND
And this is my arduino code:
#include <LiquidCrystal.h>
// LiquidCrystal display with:
// rs on pin 4
// rw on pin 11
// enable on pin 5
// d4, d5, d6, d7 on pins 0, 1, 2, 3, 4
LiquidCrystal lcd(4, 11, 5, 0, 1, 2, 3);
  // Print a message to the LCD.
  lcd.print("hello, world!");
However, nothing shows up on the LCD :frowning:
What could i be doing incorrect? I never connected the rw to the arduino, just to ground.
David
pins 0 and 1 are used by the serial port, try using different pins
Alright i moved 0 and 1 to 6 and 7 but still nothing..
LiquidCrystal lcd(4, 11, 5, 6, 7, 2, 3);
David
David
Ok, i got it working. I must of had a wire crossed..
Thanks for your help, mem.
David
As a side note, I believe the data pins are supposed to be a set of 4 sequential pins (because of "Lazy coding"). Personally, I use the LCD4Bit library since it doesn't require the RW pin and had a couple of new fun and usable functions like scrolling. Glad you got it working though.
The 'lazy coding' is actually in the lcd4bit library. LiquidCrystal has no such requirement
I was going to use that but all it displayed was Japanese-type on the lcd so i just used the example one that came with arduino software. Not sure what happened, i changed all the values in the c++ file to what worked for the arduino example code...
David
