Hello,
I am looking for help to interpret an error message. My scenario is thus:
I can read a single AHT10 sensor directly without any unusual behaviour.
However, with the same single AHT10 connected through a TCA9548A expansion board, it will loop twice, and then spit out the following error message on the console:
// console output
Free internal heap: 330568 //first loop
Chan 0 Temperature: 18.68 degrees C
Chan 0 Humidity: 18.35% rH
Free internal heap: 330624 //second loop
Chan 0 Temperature: 18.67 degrees C
Chan 0 Humidity: 18.32% rH
CORRUPT HEAP: Bad head at 0x3ffb9570. Expected 0xabba1234 got 0x3ffb8014
assert failed: multi_heap_free multi_heap_poisoning.c:279 (head != NULL)
Rebooting...
// end console output
I adapted this fellow's code for reading 4 BME280s through the multiplexer:
Rui Santos -
Complete project details at https://RandomNerdTutorials.com/tca9548a-i2c-multiplexer-esp32-esp8266-arduino/
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files.
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_AHT10.h>
Adafruit_AHT10 aht1;
// Select I2C BUS
void TCA9548A(uint8_t bus){
Wire.beginTransmission(0x70); // TCA9548A address
Wire.write(1 << bus); // send byte to select bus
Wire.endTransmission();
void printValues(Adafruit_AHT10 aht, int bus) {
TCA9548A (bus);
sensors_event_t humidity, temp;
aht.getEvent(&humidity, &temp);// populate temp and humidity objects with fresh data
Serial.print("Chan ");
Serial.print(bus);
Serial.print(" Temperature: "); Serial.print(temp.temperature); Serial.println(" degrees C");
Serial.print(bus);
Serial.print(" Humidity: "); Serial.print(humidity.relative_humidity); Serial.println("% rH");
// Start I2C communication with the Multiplexer
Wire.begin();
TCA9548A(0);
if (!aht1.begin()){
Serial.println("Could not finid AHT10 sensor on bus 0, check wiring!");
Serial.print("Free internal heap: ");
Serial.println(ESP.getFreeHeap());
//Print values for sensor 1 on bus 0
printValues(aht1,0);
delay(5000);
I tried to use the debugger, but that also gives me an error message:
//debugger
Info : Listening on port 50001 for tcl connections
Info : Listening on port 50002 for telnet connections
Error: unable to open ftdi device with description '', serial '' at bus location ''
C:/Users//AppData/Local/Arduino15/packages/esp32/tools/openocd-esp32/v0.12.0-esp32-20250707/bin/../share/openocd/scripts/target/esp_common.cfg:9: Error:
Traceback (most recent call last):
File "C:/Users/*/AppData/Local/Arduino15/packages/esp32/tools/openocd-esp32/v0.12.0-esp32-20250707/bin/../share/openocd/scripts/target/esp_common.cfg", line 9, in script
[2026-01-04T16:44:22.157Z] SERVER CONSOLE DEBUG: onBackendConnect: gdb-server session closed
GDB server session ended. This terminal will be reused, waiting for next session to start...
// end debugger
Thanks to all for any suggestions,
BM
