Hello i need a help for my project that uses the arduino uno with pulse sensor to get a heart beat rate for human and display it in LCD or Serial monitor , i used many methods and i tried many codes but no result
How have you connected that thing to the Arduino? What code do you have on the Arduino?
A link is far more useful than a picture.
Ism3lawy:
Which model of heartrate sensor?
5V operating voltage and analog output?
Or different?
PaulS:
How have you connected that thing to the Arduino? What code do you have on the Arduino?A link is far more useful than a picture.
I used the code below and the connection that in the attached picture
volatile int rate[10]; // used to get running average of HRV values
int pulsePin= A0;
volatile unsigned long lastBeatTime = 0; // used to find the time between beats
volatile int sampleCounter; // used to determine pulse timing
volatile int runningTotal; // used to keep track of pulses
volatile boolean firstBeat = true; // used to seed rate array so we startup with reasonable BPM
volatile boolean secondBeat = true; // used to seed rate array so we startup with reasonable BPM
void interruptSetup(){
// Initializes Timer1 to throw an interrupt every 1mS.
TCCR1A = 0x00; // DISABLE OUTPUTS AND PWM ON DIGITAL PINS 9 & 10
TCCR1B = 0x11; // GO INTO 'PHASE AND FREQUENCY CORRECT' MODE, NO PRESCALER
TCCR1C = 0x00; // DON'T FORCE COMPARE
TIMSK1 = 0x01; // ENABLE OVERFLOW INTERRUPT (TOIE1)
ICR1 = 8000; // TRIGGER TIMER INTERRUPT EVERY 1mS
sei(); // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED
// THIS IS THE TIMER 1 INTERRUPT SERVICE ROUTINE.
ISR(TIMER1_OVF_vect){ // triggered every time Timer 1 overflows
// Timer 1 makes sure that we take a reading every milisecond
Signal = analogRead(pulsePin); // read the Pulse Sensor
sampleCounter++; // keep track of the time with this variable (ISR triggered every 1mS
// NOW IT'S TIME TO LOOK FOR THE HEART BEAT
int H = sampleCounter-lastBeatTime; // monitor the time since the last beat to avoid noise
if ( (Signal > 520) && (Pulse == false) && (H > 500) ){
// signal surges up in value every time there is a pulse
Pulse = true; // set the Pulse flag when we think there is a pulse
digitalWrite(13,HIGH); // turn on pin 13 LED
HRV = sampleCounter - lastBeatTime; // measure time between beats in mS
lastBeatTime = sampleCounter; // keep track of time for next pulse
if(firstBeat){ // if it's the first time we found a beat
firstBeat = false; // clear firstBeat flag
return; // HRV value is unreliable so discard it
if(secondBeat){ // if this is the second beat
secondBeat = false; // clear secondBeat flag
for(int i=0; i<=9; i++){ // seed the running total to get a realisitic BPM at startup
rate[i] = HRV;
// keep a running total of the last 10 HRV values
for(int i=0; i<=8; i++){
rate[i] = rate[i+1]; // shift data in the rate array and drop the oldest HRV value
rate[9] = HRV; // add the latest HRV to the rate array
runningTotal = 0; // clear the runningTotal variable
runningTotal += rate[i]; // add up the last 10 HRV values
runningTotal /= 10; // average the last 10 HRV values
BPM = 60000/runningTotal; // how many beats can fit into a minute? that's BPM!
QS = true; // set Quantified Self flag when beat is found and BPM gets updated.
// QS FLAG IS NOT CLEARED INSIDE THIS ISR
if (Signal < 500 && Pulse == true){ // when the values are going down, it's the time between beats
digitalWrite(13,LOW); // turn off pin 13 LED
Serial.println("beat rate is: ");
Serial.print(BPM);
Pulse = false; // reset the Pulse flag so we can do it again!
jurs:
Which model of heartrate sensor?5V operating voltage and analog output?
Or different?
yes i used the model which operate at 5V and output is analog i connected the sensor at pin A0 i uploaded the code above
You can't do serial output in an ISR. Get that crap out of there. Print the heart rate in loop(), when the ISR sets the flag that says that there is a heart rate known.
Posting code that actually compiles is a good idea, unless the problem you are having is that the code doesn't compile. If that is the case, complaining that the code doesn't produce useful output is stupid.
Maybe I will leave it to someone else to explain why noobs and interrupts are such a bad combination.
Ism3lawy:
yes i used the model which operate at 5V and output is analog i connected the sensor at pin A0 the i code i uploaded it above
Did you check the raw sensor output values?
Can you confirm that the sensor takes up a heartbeat signal?
Is it a good signal, fluctuating up and down in the rhythm of a heartbeat?
Here is a short sketch to provide raw values and latest changes to Serial:
const byte samplePin= A0;
const int sampleInterval=5000; // microseconds
unsigned long lastSampleTime;
int lastSample;
Serial.begin(115200); // set serial monitor to 115200 baud
if (micros()-lastSampleTime>=sampleInterval)
lastSampleTime+=sampleInterval;
int sample= analogRead(samplePin);
Serial.print(lastSampleTime/1000000.0,3);
Serial.print('\t');
Serial.print(sample);
Serial.print('\t');
Serial.println(sample-lastSample); // change since last sample was taken
lastSample=sample;
Perhaps send some seconds of Serial output without signal (sensor attached to Arduino, no heartbeat signal present).
And also some seconds of Serial output with a valid signal (sensor attached to Arduino, with heatbeat signal present)
Heartbeat detection can only work with a good signal from the sensor.
Hi my name is Steve, I have spent a number of hours with the heartbeat sensor circuit, trying several different circuits and several different sensor combinations.Before even connecting the Arduino I wanted to see if this circuit would show a voltage change that was reflective of a heart peat pulse.What I found after several tries is that the infrared led must be aimed at a 45 degree angle with the lens of the photo-transistor with the finger tip being the vertex, in other words the infrared light must be reflected off of the finger into the lens of the photo-transistor. I found it to be very difficult to get a signal and that your finger has to be positioned just right. Eventually after holding my finger just right I was able to see a semblence of a heart beat on my scope. The scope, by the way should be set at a very slow sweep, in other words dont start out with a flat line on the scope, get the scope to show one point sweep across the screen. Once I got the heart beat to show on my scope I was ready to attach the Arduino. One trick to see if your led is transmitting light is to view the led with your cell phone camera, as it is capable of picking up infrared light,(which appears blue),and the eye cannot see this light. my email is beatlessteve@gmail.com if you have any questions, Ill be more than happy to help!
