Hello, can somebody help me with this error message?
Arduino: 1.6.5 (Windows 7), Platine: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
L_fter_Steuerung_PWM:120: error: expected declaration before '}' token
#include "DHT.h"
#include <SPI.h>
#include <Wire.h>
#include <LiquidCrystal.h> // Using version 1.2.1
#include <SC16IS750.h>
#include <string.h>
#include <NDIRZ16.h>
#define DHT1PIN A0 // what pin we're connected to
#define DHT2PIN A1
#define DHT1TYPE DHT11 // DHT 11
#define pwm 9
#define RELAY_ON 0
#define RELAY_OFF 1
#define Relay_3  8   // Relais werden den Pins zugeordnet Ventilator
#define Relay_1  10  // Ventilator
#define Relay_2  13  // Ventilator
#define Relay_4  22 // CO2 Ventil
#define Relay_5  23 // Luftbefeuchter
SC16IS750 i2cuart = SC16IS750(SC16IS750_PROTOCOL_I2C,SC16IS750_ADDRESS_BB); // CO2 Sensor
NDIRZ16 mySensor = NDIRZ16(&i2cuart);
DHT dht1(DHT1PIN, DHT1TYPE);
DHT dht2(DHT2PIN, DHT1TYPE);
const int buttonPin = 6;     // the number of the pushbutton pin
const int ledPin =  7;      // the number of the LED pin
int ledState = LOW;         // the current state of the output pin
int buttonState = LOW;             // the current reading from the input pin
int lastButtonState = HIGH;   // the previous reading from the input pin
int reading;
long lastDebounceTime = 0;  // the last time the output pin was toggled
long debounceDelay = 50;    // the debounce time; increase if the output flickers
LiquidCrystal theDisplay(12, 11, 5, 4, 3, 2);
  i2cuart.begin(9600);
   if (i2cuart.ping()) {
        Serial.println("SC16IS750 found.");
        Serial.println("Wait 10 seconds for sensor initialization...");
        Serial.println("SC16IS750 not found.");
        while(1);
    power(1);
    delay(10000);
void loop(){
 theDisplay.setCursor(0, 1);
  Serial.println("-------");
  pinMode(buttonPin, INPUT);
  pinMode(ledPin, OUTPUT);
  dht1.begin();
  dht2.begin();
  Serial.println("   Fan Speed  ");
  Serial.println("  Controlling ");
  analogWrite(pwm, 255);
  Serial.println("Circuit Digest ");
  digitalWrite(Relay_1, RELAY_OFF);  // Relay 1  Ventilator
  digitalWrite(Relay_2, RELAY_OFF);  // Relay 2  Ventilator
  digitalWrite(Relay_3, RELAY_OFF);  // Relay 3  Ventilator
  digitalWrite(Relay_4, RELAY_OFF);  // Relay 4  CO2 Ventil
  digitalWrite(Relay_5, RELAY_OFF);  // Relay 5  Luftbefeuchter
  pinMode(Relay_1, OUTPUT);  // Relay 1  Ventilator
  pinMode(Relay_2, OUTPUT);  // Relay 2  Ventilator
  pinMode(Relay_3, OUTPUT);  // Relay 3  Ventilator
  pinMode(Relay_4, OUTPUT);  // Relay 3  CO2 Ventil
  pinMode(Relay_5, OUTPUT);  // Relay 3  Luftbefeuchter
void power (uint8_t state) {
    i2cuart.pinMode(0, INPUT);      //set up for the power control pin
    if (state) {
        i2cuart.pinMode(0, INPUT);  //turn on the power of MH-Z16
        i2cuart.pinMode(0, OUTPUT);
        i2cuart.digitalWrite(0, 0); //turn off the power of MH-Z16
calling this function.
void calibrate() {
    i2cuart.pinMode(1, OUTPUT);    //set up for the calibration pin.
    i2cuart.digitalWrite(1, LOW);  //start calibration of MH-Z16 under 400ppm
    delay(10000);                  //5+ seconds needed for the calibration process
    i2cuart.digitalWrite(1, HIGH); //toggle the pin HIGH back to normal operation
  int sensorValue = analogRead(A2);
  int level = sensorValue * (11/ 1023.0);
  Serial.print ("level: ");
  Serial.println(level);
   Serial.println(sensorValue);
  reading = digitalRead(buttonPin);
   if (reading != lastButtonState) {
      lastDebounceTime = millis();
      lastButtonState = reading;
   if ((millis() - lastDebounceTime) > debounceDelay) {
       if (buttonState != lastButtonState) {
           buttonState = lastButtonState;
           if (buttonState == HIGH) {
                 ledState = !ledState;
                 digitalWrite(ledPin, ledState);
                 Serial.print("ledState ");
                 Serial.println(ledState);
void calibrate() {
Did you forget the // ?
Pressing Ctrl+T in the IDE helps a lot. You have a mismatch in your curly brackets.
You also have a semicolon at the end of setup which shouldn't be there. You also have writing on line 103 that looks like it should be in comments or something
