Number of missing semi-colons
2)
greeLEDPin is not the same as greenLEDin
3)
All your pins and variables are declared within setup() and therefore are not known in loop() (which results in errors). You will have to move them outside setup(); the sensor variables can go inside loop().
4)
You use variables that are not declared.
Thank you all, I tried to apply your advice in my code:
I tried to declare my variables outside Setup and Loop for which side effect everywhere but it doesn't seem to work...
I also added semicolons where they were missing.
Here is the new version of my code:
const int greeLEDPin = 9;
const int redLEDPin = 11;
const int blueLEDPin = 10;
int redValue = 0;
int greenValue = 0;
int blueValue = 0;
int redSensorValue = 0;
int greenSensorValue = 0;
int blueSensorValue = 0;
pinMode(greenLEDin,OUTPUT);
pinMode(redLEDin,OUTPUT);
pinMode(blueLEDin,OUTPUT);
const int redSensorPin = A0;
const int greenSensorPin = A1;
const int blueSensorPin = A2;
redSensorValue = analogRead(redSensorPin);
delay(5);
greenSensorValue = analogRead(greenSensorPin);
delay(5);
blueSensorValue = analogRead(blueSensorPin);
Serial.print("Raw Sensor Values \t Red : ");
Serial.print(redSensorValue);
Serial.print("\t Green : ");
Serial.print(greenSensorValue);
Serial.print("\t Blue : ");
Serial.println(blueSensorValue);
redValue = redSensorValue/4;
greenValue = greenSensorValue/4;
blueValue = blueSensorValue/4:
Serial.print("Valeurs recalculees \t Rouge : ");
Serial.print(redValue);
Serial.print("\t Vert : ");
Serial.print(greenValue);
Serial.println(blueValue);
analogWrite(redLEDPin, redValue);
analogWrite(greenLEDPin, greenValue);
analogWrite(blueLEDPin, blueValue);
And this time here are the error messages in their entirety:
Arduino : 1.8.6 (Windows 10), Carte : "Arduino/Genuino Uno"
C:\Users\Utilisateur\Documents\Arduino\temperature\Lampe_d_ambiance\Lampe_d_ambiance.ino: In function 'void setup()':
Lampe_d_ambiance:27:11: error: 'greenLEDin' was not declared in this scope
Lampe_d_ambiance:28:11: error: 'redLEDin' was not declared in this scope
Lampe_d_ambiance:29:11: error: 'blueLEDin' was not declared in this scope
C:\Users\Utilisateur\Documents\Arduino\temperature\Lampe_d_ambiance\Lampe_d_ambiance.ino: In function 'void loop()':
Lampe_d_ambiance:55:33: error: expected ';' before ':' token
Lampe_d_ambiance:65:16: error: 'greenLEDPin' was not declared in this scope
exit status 1
There are no more error messages! And I'm sorry if I asked questions that seemed very simple to you, I'm a beginner and I have very little knowledge of arduino programming.
Jules3000:
Now you have learned what "was not declared in this scope" means.
One style hint that might help: Start your global variable names with a capital letter. Then when you get a "not declared" error you will see if the variable was supposed to be declared inside the function (local) or outside all functions (global).
