i was using cd4021 for reading 8 pushbuttons and displaying the outputs through 8 leds/relays connected to 74hc595 through SPI. I am using cat8 of length ~20m between the arduino and ic circuit(wires are used for SCK, MISO, MOSI and 2 latches, 5V and ground). Due to the length of the wire, cd4021 is not responding to the buttons but i am able to drive the 74hc595 ic according to my will. I removed the cd4021 ics and i'm 1 74hc595 for inputs and 1 for outputs.
here is my circuit for the input..
|Q0------1n4007----button----|
|Q1------1n4007----button----|
595 |Q2------1n4007----button----|
|Q3------1n4007----button----|
|Q4------1n4007----button----|
|Q5------1n4007----button----|
|Q6------1n4007----button----|
|Q7------1n4007----button----|-----------pin 2 of arduino uno
ground----10k-----|
another ic is connected to this one..
I'm getting a flicker in the leds and the buttons are working with a delay... Kindly help me out... Here is my code
#include <SPI.h>
byte Input, Output=0, Check=1;
int j;
int s=0;
void setup(){
pinMode(7, OUTPUT);
pinMode(10, OUTPUT);//latch
pinMode(2, INPUT);//Input from buttons
SPI.setClockDivider(SPI_CLOCK_DIV2);
SPI.begin();
digitalWrite(10, LOW);
SPI.transfer(255);
SPI.transfer(0);
digitalWrite(10, HIGH);
digitalWrite(7,LOW);
attachInterrupt(0, pin_read, RISING);
}//setup
void loop(){
}//loop
void pin_read(){
s=!s;
digitalWrite(7,s);
for(j=0; j<50; j++)
delayMicroseconds(1000);
Check=1;
for(j=0; j<8; j++){
SPI.transfer(Check);
SPI.transfer(Output);
delayMicroseconds(500);
if(digitalRead(2)==HIGH){
if(bitRead(Output, j)==1)
bitWrite(Output, j, 0);
bitWrite(Output, j, 1);
}//dig check
Check = Check<<1;
}//j
SPI.transfer(255);
while(digitalRead(2)==HIGH){}
